Results 1 to 7 of 7
Thread: Thickness punch
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Thickness punch
    Hi,
    Here is my latest tool, for instrument making, but can be used for any kind of precise woodworking :
    It is a punch with a hardened steel point, that is intended to mark the wood, after roughing out, to the desired thickness, in order to guide the planing and scraping.
    When the marks disappear, you are at the good thickness.
    This tool could be found in Stradivari's shop at the golden age of violin makers and is very accurate, far better than the common way used nowadays which is to use the drill press ...
    My version has some personal touches :
    Some ebony turned knobs.
    A flat anvil for flat pieces, like this violin side (must be calibrated to 1.1 mm)
    and also a rounded one for curved surfaces like violin plates. You just need to remove the flat cap.
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 2 Users Say Thank You to Christophe Mineau For This Useful Post:
    CedarSlayer (Nov 4, 2014), kbalch (Nov 4, 2014)
    Jul 2014
    France, Brittany !
    On the stop side, I have added a couple of steel stops, with a rounded face, it gives a clear "clap" when you reach the desired depth, and you don't have it if the wood is too thick.
    This knob is a lock nut that stops the point in position. The brass part goes through the ebony and is tapped. It is pinned in the wood.
    And here you see the reason for the thickness gauge I presented yesterday.
    An example of the marks it leaves on the wood.
    Voilą,
    Christophe
    Cheers !
    Christophe
    Feb 2013
    South of Brazil.
    Hotz's Tools
    I can only say Wonderful.
    Sorry my mistakes in english.
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    WOW and WOW again...........:O)
    Jul 2014
    France, Brittany !
    Thanks Paulo and Cap'tain
    Cheers !
    Christophe
  7. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    Hotz (Nov 4, 2014)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Christophe! I've added your Thickness Punch to our Measuring and Marking and Woodworking categories, as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
  9. #7
    Amazing, a replica of a tool from the time of Stradivari. Thanks for the contribution, Christophe!
