Results 1 to 6 of 6
Thread: Tap extensor rod
    Supporting Member Cascao's Avatar
    Brasil
    Cascao's Tools
    Lightbulb Tap extensor rod
    I had a problem doing threads like that....
    So, I created a extension rod
    Now I can reach any place.
  2. The Following 4 Users Say Thank You to Cascao For This Useful Post:
    j.bickley (Oct 2, 2017), LMMasterMariner (Oct 2, 2017), olderdan (Oct 2, 2017), Seedtick (Oct 2, 2017)
    olderdan's Tools
    Very useful tool, just curious as to why you are tapping into a suspension bush.
    Brasil
    Cascao's Tools
    Polyurethane bushings are noisy when dry. I'm adding grease fittings to easly lube them.
    May 2013
    Cascao, I want to say thanks for the marvelous idea. When I first saw the picture, I did not see the tap handle hitting the shock absorber. Rather, I saw the inherent problem of keeping the tapping handle steady while initiating the thread cuts. Did the extension rod make it a big difference in ease of tapping with steadiness and better precision? I hope so. I will certainly have one made like that and maybe, use it as much as possible. I have "ten thumbs", you know. Thanks again!
    ---Joe
    Thanks Cascao! We've added your Tap Extension to our Tapping and Threading category,
    as well as to your builder page: Cascao's Homemade Tools. Your receipt:
  7. The Following User Says Thank You to DIYer For This Useful Post:
    Cascao (Oct 4, 2017)
    Brasil
    Cascao's Tools
    Quote Originally Posted by j.bickley View Post
    ---Joe
    Thanks Joe. As a side effect, I feel that with longer stem, yes is easier to spot tap misalignment.
