Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Tailstock alignment buttons
    Oct 2012
    Sometimes there are thing that come up that just stir me. WE ARE NONE NASA ENGINEERS or will we be. A few thousands will not hurt anything.
    When we look at blueprints they tell us how many of those "0" we can delete. Not everything has to be within 0.0002 - 0.0000
    Nelson
    Download plans for tailstock.
  2. The Following User Says Thank You to ncollar For This Useful Post:
    olderdan (Sep 7, 2018)
  3. #12
    Jul 2018
    Flora, MS
    Floradawg's Tools
    Thanks Mklots,
    I will make a set. When turning between centers I have always turned a 60 degree angle on a piece of round stock chucked up. It is the easiest way and like you said probably the most accurate. It helps to have a step on it to keep it from moving into the chuck.
  4. The Following User Says Thank You to Floradawg For This Useful Post:
    that_other_guy (Jul 31, 2024)
  5. #13
    Mar 2014
    Beaumont, TX
    Paul Alciatore's Tools
    I know this is an old post, but it's a great idea. I am glad I ran across it. Thanks!
    Paul A.
  6. #14
    Quote Originally Posted by Paul Alciatore View Post
    Thanks, Paul. It's a great deal quicker than turning a test piece between centers, measuring the resulting taper, and then trying to calculate the required tailstock setover, set up a DI to measure the required movement and then repeat all this until no taper is turned.
    Short tapers are best turned using the compound. For longer tapers, an offsetable (is that a word?) tailstock center is worth building if one has more than a few tapers to make. Once I have the tailstock aligned, I hate to offset it so the offsetable style appeals to me.
    For the benefit of folks who may not be familiar with them, use Google Images with a search term of
    offsetable tailstock center
    to see pictures of what I'm on about. [Google seems to understand 'offsetable' so I guess it is a word.]
    and, of course, Amazon sells them...
    https://www.amazon.com/IMPROVED-TURN...%2C117&sr=8-35
    https://www.amazon.com/Precision-Sha...%2C117&sr=8-36
  7. The Following User Says Thank You to mklotz For This Useful Post:
    Floradawg (Apr 29, 2022)
  8. #15
    Jul 2018
    Flora, MS
    Floradawg's Tools
    Thanks for the links. I didn't know about these. Might buy the cheaper one.
  9. #16
    May 2024
    totally agree with paulandreasen@gmail.com
  10. #17
    Quote Originally Posted by de witte smed View Post
    The fact that the ends are turned down is irrelevant to any accuracy concerns. No measurements are being made across the turned down sections.
    The pieces were made from a single piece of cylindrical stock. However, before they were parted off, the stock was given a light cut to ensure that it was cylindrical (not all raw stock is cylindrical).
    If you're not satisfied with the accuracy of this device, you should make or buy an alignment test bar...
    https://www.edgetechnologyproducts.c...alignment-bar/
  11. #18
    Feb 2018
    Quote Originally Posted by ncollar View Post
    Nelson
    A few thou often makes no difference when making a part. When making a precision Gage however even one thou off makes the tool useless.
