Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
Thread: Switchable Magnet | Strength Test
  1. #21
    Dec 2016
    Ralphxyz's Tools
    I use the Magswitch magnets on a fence for my bandsaw, they hold really good.
    I just played with your magnets for a couple of minutes not doing any work just lifting and pushing them around.
    So I will have to work with them to really judge the holding strength and to compare them with Magswitch.
    Ralph
  2. The Following User Says Thank You to Ralphxyz For This Useful Post:
    tiger carpenter (Jan 26, 2022)
  3. #22
    Apr 2012
    NorCal
    Saltfever's Tools
    Ralph:
    The holding power of a magnet is affected by many variables. Anything less than optimum and the loss of holding power is significant! The picture is the chart attached to my 800lb lifting magnet. Note, the thickness of the steel and the air gap are significant! What is not pictured is how material properties also affect holding power. Carbon steel has the highest power and some of the stainless steels are lowest. Cast iron is not as good as steel. If you are comparing magnets be sure all variables are the same for each. For example, your band saw table is likely a precision ground cast iron surface. The grind, or surface finish, has a big effect on magnetism. Be sure to compare the magnets in the same way.
Name:	Magnetic holding.jpeg
    Apr 2012
    NorCal
    Saltfever's Tools
    Deleted. Question already answered.
  5. #24
    Dec 2016
    Ralphxyz's Tools
    I just remembered I do have a pull scale somewhere in my shop so I could do some measurements if I find it.
    Ralph
  6. The Following User Says Thank You to Ralphxyz For This Useful Post:
    tiger carpenter (Jan 28, 2022)
