Personally, I find the set-up for this particular SAW process to be interesting. When you are here, when you so one you do not like, it is an easy click to it away. Or if it sparks your imagination. For example, if you might wonder, "what exactly is going on under that pile of stuff", you can so easily look for more information.
Submerged Arc Welding is a very cool process.
If you are interested, this is a more clear video showing the process being used to weld a very thick cylindrical section when requires multiple passes.
