Results 1 to 5 of 5
Thread: Stud welding - GIF
    mr mikey (Jan 16, 2024), nova_robotics (Jan 15, 2024)
    Sep 2018
    nova_robotics's Tools
    They're called Nelson studs in Canada. I'm not sure if the ones in the video above are Nelson brand, but they're very close. They work good.
  4. The Following 3 Users Say Thank You to nova_robotics For This Useful Post:
    Inner (Jan 15, 2024), mr mikey (Jan 16, 2024), Ralphxyz (Jan 22, 2024)
    Mar 2018
    Um, ok. Can we pretend that I don’t know what this is for, and someone might kindly explain? Tnx!
  6. The Following User Says Thank You to bob47907 For This Useful Post:
    Sep 2018
    Quote Originally Posted by bob47907 View Post
    They're pretty versatile. You can get threaded ones. I think there are probably some other styles. In the video above they're installing Nelson Studs as a form of concrete embeds like rebar. Those little mushroom caps will hold the concrete tight against the plate and keep it from separating after pouring.
  8. The Following User Says Thank You to nova_robotics For This Useful Post:
    odd one (Jan 16, 2024)
    Supporting Member tachetailleur's Avatar
    May 2022
    You can get "domestic" size versions of these for say 2-8 mm diameters but they are still quite expensive. For these smaller size studs they use a capacitor discharge method, no ferrule needed, often sold as car dent puller systems. You can search for "cdi stud welding". It's possible to weld a stud to a fairly thin plate with no marks on the opposite side. I could have used one for a recent project with stainless sheet! I believe they can do mild steel, stainless, aluminium and brass studs.
  10. The Following User Says Thank You to tachetailleur For This Useful Post:
