Results 1 to 7 of 7
Thread: Stuck engine flywheel tool
    Dec 2014
    South Dakota
    KustomsbyKent's Tools
    here's some tools I made to break a stuck engine loose by turning the flywheel. You can see the progression of the tools made in order to have enough strength to break it loose. I had also soaked the cylinders in penetrate for 2 years before I got it un-stuck!
    1950 Chevrolet COE: Stuck Engine & the Fix! - Kustom's by Kent
  2. The Following User Says Thank You to KustomsbyKent For This Useful Post:
    Jon (Apr 9, 2016)
    Thanks KustomsbyKent! We've added your Engine Turning Tool to our Engine category,
    as well as to your builder page: KustomsbyKent's Homemade Tools. Your receipt:
    Jan 2016
    Moby Duck's Tools
    Perhaps you have given this post the wrong name.
    "Engine Turning" is a method of metal decoration using a rotating tool and grinding paste.
    The tool itself is great, but was better described by the originator as a "Stuck engine flywheel tool".
    Personally I would call it a "Seized Engine Cranking Tool".
    I do appreciate the thankless good work that the editors do, so please don't take this personally.
  5. The Following User Says Thank You to Moby Duck For This Useful Post:
    DIYer (Apr 19, 2016)
    Dec 2014
    South Dakota
    I agree, this is specifically for turning the flywheel of a stuck or seized engine. I think there might be some confusion by folks that are thinking of engine turning for metal decoration.
    Can the title be updated?
    Kent
    Sure, no problem; what would you like the title to be?
    Dec 2014
    South Dakota
    please name it as "Stuck engine flywheel tool"
    Kent
  9. #7
    OK, all set. Thanks for the recommendation, that is a more suitable name.
  10. The Following User Says Thank You to Jon For This Useful Post:
    KustomsbyKent (Apr 20, 2016)
