Results 1 to 10 of 10
Thread: Stubborn driver drives through dense fog without headlights - GIF
    WorkerB (Nov 8, 2022)
    Mar 2019
    Adelaide, Australia
    She shouldn’t be allowed to drive again. Ever. A danger to herself and others. Doesn’t even know how to turn on the headlights, let alone slow down.
  4. The Following User Says Thank You to WorkerB For This Useful Post:
    Inflight (Nov 12, 2022)
    Jun 2018
    Louisiana
    They were doomed from the start. Fog that thick there is no safe spot unless there is the option of driving waaaaaay off the road
    Mar 2019
    Adelaide, Australia
    Totally agree.
    Supporting Member bob_3000's Avatar
    Aug 2020
    Quote Originally Posted by WorkerB View Post
    How are headlights possibly going to help in that situation? Are you suggesting she should be looking for light switches right then?
    She did the best she could, slow down gradually so you hopefully don't get hit from behind and hover over the brake pedal, if you don't know that than you shouldn't be on the road.
    Aug 2020
    Quote Originally Posted by TrickieDickie View Post
    Precisely, shoulder shoulder shoulder, done it many times with clenched sphincters all around.
    Fog and whiteouts, driving in Canada.
  9. #7
    Mar 2019
    Adelaide, Australia
    Hi Bob,
    I would expect a person driving a vehicle to be familiar with it’s operation, including how to operate, among other necessary items, the headlights. She claimed that she didn’t know how to turn them on!
    I think it would be beneficial as along with the headlights, the taillights are illuminated assisting those behind her to identify her vehicle. Hazard lights would also help.
    Did she really act responsibly? There appeared to still be quite some velocity involved at impact.
    Exiting the carriageway ASAP would have been better.
    Have a good day
  10. #8
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    In dense fog one can see better without headlights, Bindardundat.
  11. The Following User Says Thank You to katy For This Useful Post:
    Frank S (Nov 13, 2022)
  12. #9
    Aug 2020
    Have a good day
    Less than ten seconds passed from when they entered the fog bank to the point of the crash, there was nothing in the world (especially not turning on the headlights or looking for the switch, which is probably what she meant by "I don't know how") that was going to change the situation, blaming the driver is just wrong.
    Have you been in that situation?
    All we do is let off the gas, hover over the brake pedal and pray everyone else is doing the same thing while we either slow to a stop on the shoulder or come out the other side of the white out or fog out.
    Claiming or thinking you can do anything else is pure folly.
  13. #10
    Quote Originally Posted by bob_3000 View Post
    If you have ever traveled across Arkansas at night in a truck or car for that matter, you know that fog can appear out of nowhere Not just Arkansas but most anywhere if the conditions are right. You are absolutely correct, off the gas hover the brake pedal, try to get as far to the side as you slow. if you can warn others with Hazzard lights if you cannot see beyond the end of your hood no one else can either. Not only fog but extremely hard rain, snow, Smoke from a fire, or a dust storm. When you can't see where you are going you might as well be trying to drive using a white cane for all the good it will do you, and you don't always have time to do much of anything, let alone fumble for a switch. Try locating the correct switch in a Semi, none of them are ever in the same place from make to make or even model to model and there can be a dozen of them scattered all over
