Thread: Strong 813 test socket
    Nov 2015
    Italy
    rendoman's Tools
    Hi all!
    I built this socket from 12mm thick Teflon round rod. Screws are M3 stainless.
    The purpose is to have a strong, stable, accurate and well insulated test socket.
    I needed something able to resist to temperature and voltage, above all the socket have to keep locked the tube even in vertical position with no yielding.
    Material needed:
    - 1,5mm Teflon slice, 70mm dia
    - Heptagonal pattern
    - Spring contacts x7
    - M3x10mm screws and nuts x7
    Equipment:
    - Lathe
    - table drill
    - Bits and basic equipment
    Strong 813 test socket-dsc02822_1600x1200.jpg Strong 813 test socket-dsc02823_1600x1200.jpg Strong 813 test socket-dsc02824_1600x1200.jpg
    Strong 813 test socket-dsc02825_1600x1200.jpg Strong 813 test socket-dsc02826_1600x1200.jpg Strong 813 test socket-dsc02828_1600x1200.jpg
    Strong 813 test socket-dsc02829_1600x1200.jpg Strong 813 test socket-dsc02830_1600x1200.jpg Strong 813 test socket-dsc02831_1600x1200.jpg
    Strong 813 test socket-dsc02832_1600x1200.jpg Strong 813 test socket-dsc02833_1600x1200.jpg Strong 813 test socket-dsc02834_1600x1200.jpg
  2. The Following 4 Users Say Thank You to rendoman For This Useful Post:
    Jon (Oct 9, 2017), rlm98253 (Oct 9, 2017), Seedtick (Oct 9, 2017), tonyfoale (Oct 10, 2017)
    Thanks rendoman! We've added your Test Socket to our Electrical category,
    as well as to your builder page: rendoman's Homemade Tools. Your receipt:
    rendoman (Oct 12, 2017)
  6. The Following User Says Thank You to tonyfoale For This Useful Post:
