Stone block cutting machine.
Extracting quarried stone block - GIF
Stone splitting plug and feather - GIF
Quarry hydraulic rock splitter - GIFs
Quarry wire saw - GIF
Quarry sawing - GIFs
nova_robotics (Feb 20, 2023), that_other_guy (Feb 25, 2023)
Jon (Feb 22, 2023)
Indeed, these limestone blocks are "harvested'' from quarries; measuring 27" x 9" x 11". I know this particular fellow, he is from Gozo, owner of NTG Contractors, the quarry is overlooking the famous Dwejra Bay with the Fungus Rock, ex Azure window & inland sea...
The dust is not much of a problem, as it is quite damp when being cut & settles easily. Blocks that size weigh about 150 lbs each,
As mentioned, custom measurements are ordered, and in this size up to 6 foot lengths are ordered by the Master Mason for particular uses, eg Lintel blocks to span over door-ways. Houses are built using one 9'' block, but larger buildings use 2 thicknesses thick walls to support larger concrete-slab roofing.....
nova_robotics (Feb 26, 2023)
