Results 1 to 4 of 4
Thread: Squaring raw stock on the milling machine - #tipsblitz19 #tipblitz19
    MachineNZ's Avatar
    Jun 2019
    MachineNZ's Tools
    #tipsblitz19 - a collaboration of tips & tricks videos by YT creators being uploaded this weekend (15-9-19)
  2. The Following User Says Thank You to MachineNZ For This Useful Post:
    Jon (Sep 14, 2019)
    Supporting Member craig9's Avatar
    Jul 2019
    Hobart, Tasmania
    craig9's Tools
    Hi Kevin,
    Saw this on Youtube and enjoyed watching the process. Again - that flycutting finish is second to none. I should break mine out more often!
    Cheers,
    Craig
    MachineNZ's Avatar
    Jun 2019
    MachineNZ's Tools
    Quote Originally Posted by craig9 View Post
    Hi Kevin,
    Cheers,
    Craig
    Thanks Craig. With the right feeds, speeds and cutting tool the flycutter can give great results.
    Cheers
    Kevin
    MachineNZ
    Jul 2019
    Hobart, Tasmania
    craig9's Tools
    Quote Originally Posted by MachineNZ View Post
    Yes - I use an HSS bit ground with a bit of positive rake, honed on a stone, and a generous nose radius. From there, I use as fast a rotation speed as I have the guts for, plenty of lube, and as slow a feed rate as I have the patience for
    It gives great results, to my novice eye almost looks like a ground finish, but I don't use the thing often enough.
    Cheers,
    Craig
