Results 1 to 4 of 4
Thread: Spot welding machine - video
    Spot welding machine. By Creative Think. 7:37 video:
    New plans added on 01/10/2025: Click here for 2,694 plans for homemade tools.
    katy (Jul 19, 2023), kboy0076 (Jul 28, 2023), rlm98253 (Jul 19, 2023), Scotty1 (Jul 23, 2023)
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    Man, 0h man, you need at least 1 sq, inch to carry 1000 amps. Positive and negative on an AC output and then dry joints and no lugs on the cable connections. I have tried this and found that you get about 1 volt per winding on a microwave transformer core with a 230 volt input. With his setup he is probably going to ge a max. of 100 amps.
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    But he printed 1000 A on his wooden box and published it on YT - how could this be wrong???
    Make it DC with some big caps and then you might get to 1000A for a short time...
    Dec 2020
    With it being AC, there is NO + and - . AC has no polarity out of a transformer. A cord clamp or grommet of some sort should be used around the AC input cord. Also crimped ring terminals should be used on the wire. It looks like #12 stranded copper, so the most it can safely carry is 25 amps of current. With voltage that low it would have been a good idea to use electrical conductant grease on the wire terminals and lead wires from the terminals.
