Results 1 to 9 of 9
Thread: Spiral smoke pattern from burning wind turbine - GIF
    nova_robotics (Aug 26, 2023), piper184 (Aug 26, 2023)
    Sep 2018
    nova_robotics's Tools
    I'd love to know what the typical failure mode is that causes this. High winds overcoming the brakes (probably this case)? Faulty variable pitch blade actuator? Bad bearings overheating and igniting the grease? Electrical fault? Something else? These things are large and expensive enough that they should have a beefy fire suppression system onboard. I've installed gensets in little 20 ft seacans and they had to have quite expensive FM200 fire suppression systems. You would think the prospect of losing a multi-million dollar piece of equipment would lead to investing in some robust backup systems.
    Sockmonster's Avatar
    Looks like a second one is smoking in the far back.
  5. The Following User Says Thank You to Sockmonster For This Useful Post:
    Supporting Member drivermark's Avatar
    Oregon City, Or. USA
    Quote Originally Posted by Sockmonster View Post
    There's the backup
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    Others I've seen like this were the result of lightning strikes. The fact that two of them are on fire would seem to bear that out as a possibility. Also, the wind appears to be blowing a pretty good clip, so there could be a storm involved. Maybe, a two-mode failure--lightning takes out some critical system, allowing the turbine to spin ungoverned. That could be why the closer one is spinning, but the farther one is not.
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
  8. The Following User Says Thank You to schuylergrace For This Useful Post:
    nova_robotics (Aug 27, 2023)
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    Quote Originally Posted by schuylergrace View Post
    It looks like the further one has a blade missing?
  10. #7
    So I wonder how much the smoke emissions from these events negate the greenhouse gas savings.
  11. #8
    Sep 2018
    It's pretty tiny in the grand scheme of things. These things actually make quite a bit of electricity. What kills it is if the turbine was early in its usable lifespan. If it's a young turbine then it might not have had a chance to make back the carbon it took to manufacture the thing. I've heard the payback can be as little as 6 months, but in all likelihood that's an overly optimistic number from a manufacturer, so take that with a big old grain of salt. These things look old as hell though so who knows?
  12. #9
    Mar 2018
    Never seen a wind turbine turn that fast. Looks like a high wind situation and like nova_robotics said, catastrophic brake failure, especially given that two of them are burning in the same field. I think Hans Pearson is right, the one further back is missing a blade AND burning.
    "This country was founded by a bunch of slave owners that told us all men are created equal..." - George Carlin
