Results 1 to 5 of 5
Thread: Spinning an aluminum can in a motor stator - GIF
  2. The Following 4 Users Say Thank You to Altair For This Useful Post:
    DSTP (Sep 11, 2023), nova_robotics (Sep 11, 2023), piper184 (Sep 12, 2023), Rangi (Sep 12, 2023)
    DSTP's Tools
    What's the purpose of the tapping?
  4. The Following 2 Users Say Thank You to DSTP For This Useful Post:
    Haroun (Sep 11, 2023), piper184 (Sep 12, 2023)
    May 2015
    Tasmania, Australia
    Bony's Tools
    And Al has very little magnetic attraction?
    Aug 2012
    Australia
    desbromilow's Tools
    hoping the tapping was because some of the pole keepers may have been a little loose
    Aug 2012
    Australia
    desbromilow's Tools
    Quote Originally Posted by Bony View Post
    Aluminium isn't magnetic, but the induced currents in the aluminium (because it is a conductor) create a magnetic feild which interacts with the rotating feild in the stator. Copper isn't magnetic either, yet moves in a magnetic feild when it has a current in it for the same reason (think coils in a loudspeaker). The forces exerted on a conductor (with current present) in a magnetic feild are defined by Lenz's law. Lenz's law has no consideration regardign if the conductor is a magnetic material or not since it is the current which is interacting, not the material containing the current.
    The iron/steel in a commercial motor is predominantly there to help shape and concentrate the magnetic field... it also adds some other effects like rotational inertia, etc but the principal purpose is to shape the flux field to improve magnetic coupling, and therefore improve efficiency.
  8. The Following 6 Users Say Thank You to desbromilow For This Useful Post:
    Altair (Nov 30, 2023), flyfr8rs (Sep 16, 2023), piper184 (Sep 16, 2023), Ralphxyz (Sep 15, 2023), Tooler2 (Sep 16, 2023), Toolmaker51 (Sep 17, 2023)
