Results 1 to 4 of 4
Thread: Soldering Circuit Boards - Through Hole Tips & Tricks (4K)
    Supporting Member tsbrownie's Avatar
    Feb 2019
    tsbrownie's Tools
    How to get good results when soldering through hole circuit boards and components. Tips and tricks I've learned over the past 58 years that I've not seen elsewhere.
    WARNING: Soldering can be dangerous. There is risk of burns, fire, shock and electrocution. Lead is toxic. Soldering releases toxic fumes. Etc. If you dont' know, learn first or don't do it.
  2. The Following 2 Users Say Thank You to tsbrownie For This Useful Post:
    freddo4 (Oct 28, 2020), sossol (Oct 28, 2020)
    jdurand's Tools
    not even maybe on the second from the right.
  4. The Following User Says Thank You to jdurand For This Useful Post:
    tsbrownie (Oct 29, 2020)
    jdurand's Tools
    also, trim leads before soldering. The recoil from trimming can crack a solder joint. Flux is your friend, make sure it's the right one for the job.
    Thanks tsbrownie! We've added your Soldering Tips to our Electrical category,
    as well as to your builder page: tsbrownie's Homemade Tools. Your receipt:
