Thread: Small motor generator (pulse motor generator) powered with solar panels
    sciencetoolbar's Avatar
    Apr 2017
    Small motor generator (pulse motor generator) powered with solar panels-motor-generator-300x170.jpg
    The presented pulse motor generator generates Ac voltage. The input pulse current passes through a input coil iron less (bobbin) specifically positioned. The power wheel is composed of a fidget spinner with iron insertions and three neodymium magnet discs disposed N-N-N. The reed switch is positioned on the input coil The pulse motor generator is powered with two small solar panels. The reed switch is actuated by bringing a magnet near it. Once the magnet is pulled away from the switch, the reed switch will go back to its original position.
    Materials used to build pulse motor generator:
    1.fidget spinner with iron insertions -- the flywheel
    image description
    2. three neodymium magnet discs
    image description
    3. two small solar panels -- power source
    image description
    Details :
    Voltage: 5V
    Power: 1.2W
    Current: 240 mA
    Material: Monocrystalline
    Size: 110 x 69mm
    4. Step-up Module with adjustable booster power supply module
    image description
    AeroSemi MT3608 1.2MHz 2A Step Up Converter
    2A maximum output current
    2.0 to 24VDC input voltage range
    28V maximum output voltage (trimpot adjustable)
    93% peak efficiency (~200mA output current at 5Vin, 12Vout)
    36 x 17 x 14mm
    5. Coil iron less from a syncronous motor 230 V -- used to "capture" the magnetic flux gnerated by the pulse motorimage description
    6.bobbin -- coil iron less used to produce a repulsive force
    image description
    7. reed switchimage description
    8. led circuit
    All the details : Motor generator, easy to replicate, powered with solar panels
  2. The Following User Says Thank You to sciencetoolbar For This Useful Post:
    PJs (Apr 19, 2018)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Thanks for sharing this and nice to see a post these simple experiments with simple components! Went through you website and looked at all your builds.
    PJ
    Mark Twain
