Results 1 to 9 of 9
Thread: Slide hammer center punch
    I have problems with the center punch walking away from the point to be marked while I reach for the hammer to tap the punch. To solve this I attached the hammer to the punch. Place the punch where needed, raise the hammer slug and let it drop and you're done.
    The punch itself is a long 1/4" rod with a hardened point fitted to the end and held in place with a small setscrew. The hammer is a steel slug fitted with a bored out 3/8" guide tube that is a smooth sliding fit on the punch. An aluminum end cap protects the punch tip when the tool is stored.
    All assembled, it looks like this...
    A small hole in the end of the hammer slug, closed with a setscrew, holds additional punch tips.
  2. The Following 19 Users Say Thank You to mklotz For This Useful Post:
    baja (Feb 28, 2020), Captainleeward (Jan 19, 2018), CookieCrunch (May 28, 2018), Drew1966 (Jan 17, 2018), Jon (Feb 26, 2016), kbalch (Feb 26, 2016), Moby Duck (Jan 27, 2017), mwmkravchenko (Feb 27, 2020), oldcaptainrusty (Jan 18, 2018), PJs (Feb 29, 2016), Priemsy (May 26, 2018), rendoman (Feb 29, 2016), rgsparber (May 26, 2018), rlm98253 (Jan 17, 2018), Scotsman Hosie (Apr 30, 2018), Sculptorjohn (Mar 2, 2016), StephenL (Jan 19, 2018), thoms_here (Jan 14, 2017), tom petersoin (Mar 11, 2016)
    Thanks mklotz! We've added your Tap to our Measuring and Marking category, as well as to your builder page: mklotz's Homemade Tools. Your receipt:
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi Marv,
    One question, where do you put your hand ? No risk of having your fingers pinched with the sliding sleeve ?
    Good idea anyway.
    Thanks,
    Christophe
    Cheers !
    Christophe
    Facebook : La Belle Note
    Quote Originally Posted by Christophe Mineau View Post
    Hi Marv,
    Good idea anyway.
    Thanks,
    Christophe
    The second picture shows the hammer fully seated on the rod that holds the punch. Note that a section of the rod above the tip is still visible. The hammer section can't reach that area. That's where you put your fingers.
    Unlike my other slide hammer design...
    http://www.homemadetools.net/forum/s...7212#post36644
    on this one I usually do not drop the hammer and let it slide freely down the rod bearing the punch. Rather, while holding the rod as described above, I grasp the hammer with my other hand and use it to tap on the top of the rod.
    The fundamental idea behind both these tools is that the hammer is attached to the punch and, as a result, you don't lose registration while searching for and grasping the hammer.
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Marv,
    I like both of your slide hammer center/prick punches. Do you have a preference over one or the other?
    Thanks for the postings.
    Paul
    Marv,
    Paul
    Actually, I like them both but for different tasks. The one with the smaller hammer is something of a light-weight. I designed it to be a prick punch and it does that job well but it doesn't leave a very deep impression. I needed a real center punch and when I designed it I retained the captive slide hammer design but made it heavier so it would leave a deeper impression.
    Sensible people will probably say, "Why don't you just learn to pick up the hammer without moving the punch?" and they would have a point. Still, at heart I'm as much a wannabe tool designer as I am a model builder, so I get lots of satisfaction out of designing specialized tools.
  8. The Following 4 Users Say Thank You to mklotz For This Useful Post:
    baja (Feb 28, 2020), Paul Jones (Feb 29, 2016), thoms_here (Jan 14, 2017), Toolmaker51 (Jan 20, 2018)
  9. #7
    thoms_here's Avatar
    Sep 2015
    Arkansas
    This is a great looking tool and a great idea! I hate using a cheap automatic punch that hardly leaves a dimple. Thanks for posting.
  10. #8
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Sazam I want one of those slide slammers...Hammers...:O) nice tool for sure.
    P.S. I was gonna think of that...but forgot he he
  11. #9
    Aug 2016
    wizard69's Tools
    Nice looking tool!
    Having messed up a few layouts requiring waling the punch point over to where it should be I'm always looking for a better way. Which brings up the question what do you do if you need you two hands for something other than lifting the weight up? I'm on the look out for a spring loaded solution that would come in handy at work. Sometimes the work is vertical or even upside down making gravity your enemy.
    Yep, I just put a little work in on a drilling guide to be used on extrusions and yes it is very satisfying. You do seem to be very busy with tool development, I actually look forward to your posts.
