Results 1 to 7 of 7
Thread: Skid steer mounted post driver - GIF
  2. The Following 5 Users Say Thank You to Jon For This Useful Post:
    baja (May 16, 2021), johncg (May 16, 2021), nova_robotics (May 15, 2021), rlm98253 (May 15, 2021), Scotty1 (May 15, 2021)
    Supporting Member Isambard's Avatar
    Aug 2019
    Hawke's Bay, New Zealand
    Looks like the erecting geometry needs revisiting...
    Dec 2017
    NeiljohnUK's Tools
    They've been using similar/same machines to insert crash barrier posts along the sides or a local Motorway recently, certainly speeds the process.
    1:48 video:
  6. The Following User Says Thank You to Jon For This Useful Post:
    nova_robotics (May 18, 2021)
    Aug 2019
    Interesting, it doesn't appear to have any angular adjustment. Be limited to flat terrain.
    Downunder our way, on flattish terrain for the likes of vineyards & espalier orchards,
    front end loader buckets are the post drivers of choice, so much quicker...
    Unkle Fuzzy's Avatar
    Near Monkeytown, USA
    I just wonder how it does, say at my house when it hits sandstone 18" down.
  9. #7
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Here something of interest . A Kiwi called Jim Fairbrother invented the hydraulic post driver: https://www.transag.co.nz/kinghitter
    I think the modern hydraulic driver heads developed from the rock breakers used on excavators in quarries and for building demolition work. Certainly easier to use and with a quick-hitch can be swapped out with a hole borer which may be needed in some substrates.
    Another guy by name of David Kennett invented an electric post driver which was built around an Aluminium ladder frame and could be run off an ATV/farm bike fitted with an frame to carry a generator. I saw one of these operating at an A & P Show and it was amazing. Could even drive a post horizontally into a bank!
    Just looked for it and the company has been de-registered in NZ but there is a company of the same name in Israel that does construction work but it is not shown in there product lists?
    https://patents.google.com/patent/US7823654B2/en
    Last edited by NortonDommi; May 18, 2021 at 05:56 PM. Reason: Add info and then correct a spelling mistake.
