Results 1 to 4 of 4
Thread: The simplest lathe tool height gauge.
    Mar 2018
    Rorschach's Tools
    I came up with this one years ago to help me set lathe tools quickly and easily.
    It's made from an old square, I got this one with some old tools, it wasn't terribly accurate and I have several nicer ones in this size. An an aside I believe this to be homemade, maybe a school project from long ago.
    This is so simple to make it you can do it in literally a few seconds.
    Take a sharp scriber or lathe dead centre and put it in your headstock. Place the square on the bed of the lathe (or cross slide if you prefer, I use the bed as I have flat ways) And use the scribe to scratch a line into both sides of the square "blade".
    Done, that's it! Your tool is ready to use.
    If you have a gap bed lathe and can't get close enough to the headstock, lock down your tailstock and use this instead, it will be plenty accurate enough I am sure.
    I added a picture, though you probably don't need it. You should be able to make out the scribed line on the blade about halfway up.
    Attached Thumbnails Attached Thumbnails The simplest lathe tool height gauge.-img_20180311_100204.jpg
  2. The Following 3 Users Say Thank You to Rorschach For This Useful Post:
    Paul Jones (Mar 13, 2018), PJs (Mar 12, 2018), volodar (Mar 12, 2018)
    Thanks Rorschach! We've added your Tool Height Gauge to our Height and Depth Gauges category,
    as well as to your builder page: Rorschach's Homemade Tools. Your receipt:
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Rorschach,
    I like it and such a simple approach that is easy to implement. Thank you for the directions.
    Regards,
    Paul Jones
    Mar 2018
    Rorschach's Tools
    Rorschach,
    Regards,
    Paul Jones
    No problem, I also like it's simplicity. For those on a tight budget it also saves a lot of money and space, you can use a square you already own if needed, after all it's only a scratch mark on the side of the blade, it doesn't affect its function in any way. I only used this square because otherwise it would have gone in the bin.
