Results 1 to 10 of 11
Thread: Simple welding helmet modification
    Supporting Member theeddies's Avatar
    Mar 2019
    Georgia, US
    theeddies's Tools
    Download plans for welding tools.
  2. The Following 28 Users Say Thank You to theeddies For This Useful Post:
    Andyt (Sep 19, 2019), baja (Sep 19, 2019), Big-Pete (Sep 19, 2019), bobu20 (Nov 12, 2021), carloski (Jun 13, 2022), davesrepair (Sep 30, 2024), DuayneI (Sep 18, 2019), Duke_of_URL (Jun 13, 2022), emu roo (Apr 23, 2024), freddo4 (Jun 14, 2022), Gregraper33712 (Sep 23, 2019), Gromet (Sep 19, 2019), high-side (Sep 21, 2019), homey_g (Nov 16, 2021), Inner (Sep 18, 2019), jffryplsn49 (Nov 10, 2022), JoeVanGeaux (Nov 11, 2021), Jon (Sep 20, 2019), kboy0076 (Apr 23, 2024), lassab999 (Nov 12, 2021), Marine2171 (Sep 22, 2019), MeJasonT (Sep 19, 2019), nova_robotics (Jun 17, 2022), olmike (Apr 24, 2024), rgsparber (Aug 6, 2024), rlm98253 (Sep 18, 2019), sak778 (Nov 11, 2021), sossol (Nov 11, 2021)
    Also helps with visibility. Keeps light from reflecting off the back of your lense and blinding you. As I get old.....er, I need all the help I can get.
  4. The Following 4 Users Say Thank You to ibdennyak For This Useful Post:
    baja (Jun 14, 2022), DuayneI (Sep 18, 2019), freddo4 (Jun 14, 2022), theeddies (Sep 18, 2019)
    Mar 2019
    Georgia, US
    theeddies's Tools
    Absolutely, I have used this so long, I totally forgot about the glare. Thanks!
    Thanks theeddies! We've added your Welding Helmet Modification to our Welding category,
    as well as to your builder page: theeddies's Homemade Tools. Your receipt:
    Jun 2018
    Louisiana
    That is a good idea
  8. The Following User Says Thank You to TrickieDickie For This Useful Post:
    theeddies (Sep 22, 2019)
    Mar 2019
    Georgia, US
    theeddies's Tools
    Thanks. It has worked well for me.
  10. #7
    Dry Gulch, Tx
    Crusty's Tools
    Did it to my hood this weekend. It's a glare killer for sure. Thanks for reminding me of this tip.
  11. The Following User Says Thank You to Crusty For This Useful Post:
  12. #8
    Mar 2019
    Georgia, US
    theeddies's Tools
    Good deal. You are welcome. All the best!
  13. #9
    Aug 2012
    Australia
    desbromilow's Tools
    I did something similar, but instead of permanent rivets, I attached old shirt buttons (with a small piece of plastic tubing underneath as a standoff (about 2-3mm high)) and then used the sewing machine to make button holes in the cloth, that way it can be removed for cleaning/ replacement. A 1mm drill to make some holes for the thread, and then sewing cotton as per normal to hold the button in place, then soak the thread with CA glue once finished to lock it in place.
    My driver was glare first, followed by sparks second.
  14. The Following User Says Thank You to desbromilow For This Useful Post:
    theeddies (Sep 23, 2019)
  15. #10
    Mar 2019
    Georgia, US
    theeddies's Tools
    If I welded more, making it removable would be a necessity. Your method is a great cheap idea for that. I have thought of using button snaps in the past. Thanks!
