The metal guide is positioned exactly half way across the cutter (eg.. an 8mm cutter will cut a 4mm notch), the holes in the router base casting are thread tapped so it can be removed easily when the router isn't being used in the table position
the guard on the back is folded from aluminum sheet to protect the user from the back of the cutter and from flying wood chips
