Low cost dust collectors give you powerful suck flow but low watt.
fergiomaria (Nov 1, 2022), Improvised DIY (Nov 1, 2022), Toolmaker51 (Oct 31, 2022)
Thanks Didpoolhall! We've added your Dust Collector Blower to our Dust Collectors category,
as well as to your builder page: Didpoolhall's Homemade Tools. Your receipt:
I'm interested in centrifugal blowers for the same reason, though mine will be grinding and metal sanding, not wood.
Q; at 13:40, it appears cyanoacrylate glue (Super Glue aka Hot Stuff) is used to reinforce threads into the MDF board. Do the holes need re-tapping, or does it soak in enough bolt enters normally?
A centrifugal blower has a very high pressure, gives you high suction flow but lower watt than radial blower but not like standart dust collector dust that can't come into a blower like radial blower. this is not MDF but HMR more solid and harder than MDF but i give super glue make more harder make more treaded durable, maybe if possible in future i give T nut.
