Thread: A simple chamfering fixture for my 1" belt sander
    May 2018
    Boring, OR
    CharlesWaugh's Tools
    I'm working on a design for a campstool and I need to chamfer a bunch of small pieces quite accurately, so I built a fixture.
    Charles Waugh
    www.charleswaugh.com
  2. The Following User Says Thank You to CharlesWaugh For This Useful Post:
    mklotz (Oct 13, 2020)
    Threads in wood can be problematic.
    Alternatively, the block with the screw could be replaced with a block similar to the fixed block on the left. It too would have a 45 degree angle* but would be free to move left and right. A slot with a screw into the baseplate would allow it to be clamped into place after positioning for the desired amount of chamfer.
    A long time ago, I made something similar but handheld to be used against a rotating sanding disk. Picture a wooden V-block with the bottom of the V cut away a bit. A block slid down one side of the V would expose its edge to the sander through the cutout. It worked well for the few parts I made with it. I'd like to show a picture but I fear it ended up in the fireplace many years ago.
    * By altering this angle on both blocks, the angle of the chamfer relative to the centerline of the part can be changed.
