Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Shortening screws
    Aug 2016
    wizard69's Tools
    Quote Originally Posted by thehomeengineer View Post
    Hi Philip
    Hope you and your wife are keeping well.
    I made the shims from three different thickness of material I have ordered some 0.5 mm but that was back in January from eBay coming via China but it hasn’t arrived yet. These were cut on a CNC router and made to suit the rivet shortening tool hole pitches. All I do is gang the shims together to get the required length.
    All the best
    Andy
    Thanks for yet another fantastic post. It might be worth noting that I didn't grasp the scale of this tool until I saw the photo with the file. It might help to throw a scale in the photos from time to time.
    In any event once I realized the scale it was like, man I have all sorts of scrap to make something similar from. The shims might be an issue without a CNC but that can be addressed. This is obviously a great idea in that it stimulates the mind and solves problems.
  2. The Following User Says Thank You to wizard69 For This Useful Post:
    thehomeengineer (Apr 29, 2020)
  3. #12
    Supporting Member 2gsg2_muc's Avatar
    Aug 2021
    Munich
    2gsg2_muc's Tools
    Thumbs up Crimping Tool with screw shotrtening
    Hallo,
    ich benutze seit Jahrzehnten eine einfache billige Crimpzange für diesen Zweck.
    zum Beispiel diese für M3 bis M5 Gewinde, gibt es auch für zöllige Gewinde:
    https://www.amazon.de/InLine-43054-C...s%2C529&sr=8-2
    Zum crimpen benutze ich jedoch bessere Zangen, zum Abisolieren ist diese gut, sehr gut jedoch zum kürzen von Schrauben, da diese in das vorhanden Gewinde eingeschraubt werden und dann abgeschert werden. Beim herausdrehen wird das Gewinde nachgeformt und kann direkt ohne Nachbehandlung neu eingeschraubt werden.
    Günter
    Last edited by 2gsg2_muc; Dec 1, 2022 at 05:32 AM. Reason: konnte kein foto hochladen
  4. #13
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    Shortening screws-image.jpgClick image for larger version.
    Hallo, Gunter!
    Welche Zange wuerdest du benutzen? Die am linken Sind Krimpenzwange, Oder? Und wie Sind schrauben gekurzt werden mit denen?
  5. #14
    Berkshire UK
    thehomeengineer's Tools
    Quote Originally Posted by 2gsg2_muc View Post
    Hallo,
    Günter
    Hello,
    I've been using a simple cheap crimping tool for this purpose for decades.
    For example these for M3 to M5 threads, there are also inch threads:
    However, I use better pliers for crimping, these are good for stripping, but very good for shortening screws, as these are screwed into the existing thread and then sheared off. When unscrewing, the thread is reshaped and can be screwed in again directly without post-treatment.
    Gunter
    Hi Gunter
    As with all engineering processes there is always more than one way. The most important thing is the result. If I had only one bolt to shorten a hacksaw and file or maybe a linisher will do, on larger diameter bolts/screws. My favourite pliers for smaller bolts up to 3mm/1/8".
    But when shortening many bolts for a model, the consistent length is great so all the bolts look the same with the correct amount of thread poking out of the top of each nut.
    Hallo Günter
    Wie bei allen Engineering-Prozessen gibt es immer mehr als einen Weg. Das Wichtigste ist das Ergebnis. Wenn ich nur eine Schraube hätte, um eine Bügelsäge und eine Feile zu kürzen, oder vielleicht ein Linisher, würde es bei Schrauben/Schrauben mit größerem Durchmesser reichen. Meine Lieblingszange für kleinere Schrauben bis 3mm/1/8".
    Aber wenn Sie viele Schrauben für ein Modell kürzen, ist die einheitliche Länge großartig, sodass alle Schrauben gleich aussehen und die richtige Menge an Gewinde aus der Oberseite jeder Mutter herausragt.
  6. #15
    Aug 2021
    Munich
    2gsg2_muc's Tools
    Hallo Philip,
    die linke Zange ist die von mir beschriebene. Um den Drehpunkt herum sin drei Gewinde M2, M3, M3,5 M4 und M5 zu sehen. Die Zange wird soweit geöffnet, dass man durch das Gewinde hindurch sehen kann dann wird die Schraube von der Gewindseite soweit eingeschraubt bis die Schraube mit der gewünschten Länge zwischen Schraubenkopf und Zange minus 4 mm herausschaut. Also wenn die Schraube 4mm lang sein soll, wird diese soweit eingedreht bis der Kopf an der Zange anliegt. Jetzt wird durck schließen der Zange das Gewinde abgeschnitten, das erfordert je nach Schraubendurchmesser mehr oder weniger Kraft. Das gekürzte Gweinde fällt jetz aus der Zange heraus. Jetzt dreht man die Schraube aus der Zange heraus, wobei das abgeschnittenen Gewinde so geformz wird, dass die Schraube ohne weitere Behandlung benutzt werden kann. Natürlich kann man auch von der Gewindeseite auch messen, um wieviel die Schraube gekürzt werden soll. Wenn man zum Beispiel eine Küzung vo 8mm benötigt, darf man nur 4mm Gewinde messen.
    Viel Erfolg
    Günter
  7. The Following User Says Thank You to 2gsg2_muc For This Useful Post:
    Philip Davies (Dec 1, 2022)
