Results 1 to 8 of 8
Thread: Shop fabbed Ball Joint Fixture for Lower Control Arm Fabrication
    May 2012
    Byron, Michigan
    astroracer's Tools
    Building the Lower Control Arms for my van project required a book matched set of fixtures to hold the lower ball stud mounting plates in position.
    I designed these in 3D CAD and built them in the shop. Setting ball joint angles precisely was the important part.
    This is a compound tip. 4 1/2 deg down and 3 degs in. Modeling the pieces in 3D let me measure everything very accurately. A few cuts in the bandsaw and a little time on the belt sander and everything was good.
    This is the piece I am locating. It bolts into the fixture which is then screwed down to my jig table.
    See next post.
  2. The Following 3 Users Say Thank You to astroracer For This Useful Post:
    kbalch (Jan 27, 2016), PJs (Jan 27, 2016), Toolmaker51 (Apr 16, 2018)
    May 2012
    Byron, Michigan
    astroracer's Tools
    This is the end product. Two lower control arms for my BadAst Project.
    Shock mount welded in and some paint thrown on.
    Mark
  4. The Following 7 Users Say Thank You to astroracer For This Useful Post:
    emu roo (Jan 9, 2025), extropic (Nov 19, 2017), hansgoudzwaard (Aug 29, 2018), Jon (Jan 27, 2016), kbalch (Jan 27, 2016), PJs (Jan 27, 2016), Toolmaker51 (Apr 16, 2018)
    Thanks astroracer! We've added your Ball Joint Fixture to our Suspension category, as well as to your builder page: astroracer's Homemade Tools. Your receipt:
    Quinton 357 (Jun 30, 2020)
    Jul 2017
    How did you determine the angle needed?
    May 2012
    Byron, Michigan
    astroracer's Tools
    Quote Originally Posted by jackman View Post
    The angles were determined with a suspension design program. Kingpin, caster and camber were all designed into the angles and setting them up in the fixture was key. There is plenty of adjustment of course but getting the angles right the first time will make for a suspension that is easily set up and easily aligned.
    Mark
    Apr 2012
    NorCal
    Saltfever's Tools
    Quote Originally Posted by astroracer View Post
    The angles were determined with a suspension design program. . . .
    Mark
    The name of that program would be really helpful. Nice idea for the fixture . . . thanks for sharing.
  10. #7
    May 2012
    Byron, Michigan
    astroracer's Tools
    https://www.susprog.com/
    Here you go. This is about the best one out there as far as I know. Check it out.
    Mark
  11. The Following User Says Thank You to astroracer For This Useful Post:
    hansgoudzwaard (Nov 13, 2018)
  12. #8
    Apr 2012
    NorCal
    Saltfever's Tools
    Thanks, Mark . . . very much appreciated. Sorry for my slow response. The program looks interesting and agree that is is one of the better ones. I am still checking it out but it looks like more than adequate for what I need.
