Thread: ships wheel to a wooden bolt
    cyme's Avatar
    Hi
    I have been asked to make a gate with a ships wheel that you would use to turn to move the bolt in and out to open it
    has anyone ever done this and how would i work out the ratio of cogs to the long wooden bolt
    any help greatly received
    cy
  2. The Following User Says Thank You to cyme For This Useful Post:
    Captainleeward (Jan 21, 2017)
    Without getting into the complexity of pitch diameters of gears, here's an approximation that will get you in the ball park.
    Assume
    L = distance bolt must retract to allow gate to be opened
    N = desired number of revolutions of wheel needed to retract bolt
    Then the circumference of the gear attached to the wheel, C, must be approximately
    C = L / N
    and the diameter of the gear, D, must be
    D = C/pi
    Rack and pinion assemblies are commercially available but they are likely to be expensive. Think about making your own.
