Results 1 to 5 of 5
Thread: Shifter Knob Adapter Bushing
    May 2012
    Byron, Michigan
    astroracer's Tools
    Doing a trans and shifter swap in my '56 wagon. A friend at work brought in an old red metalflake shifter knob he had in his stash. He "thought" I could use it... It looks tons better in the car then the aluminum T handle.
    The only issue was it didn't fit. The shifter has a 1/2-20 thread and the new knob is 5/8-16. So! Into the machine shop I go! I used a 5/8" diameter aluminum cutoff and drilled and tapped one end for the shifter handle thread. 1/2-20.
    I chucked the stock up in the lathe and cut the 5/8-16 thread. This pic was after the 3rd pass I think.
    All done and another pic with a test nut threaded on.
    Continued...
  2. #2
    May 2012
    Byron, Michigan
    astroracer's Tools
    Test fit into the knob.
    I trimmed it off in the band saw and threaded it into the knob.
    I think this looks good!
    Mark
  3. The Following 4 Users Say Thank You to astroracer For This Useful Post:
    Jon (Mar 17, 2016), kbalch (Mar 17, 2016), PJs (Mar 17, 2016), scoopydo (Mar 18, 2016)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Wow, what a gorgeous knob. Nice work!!
    Ken
    May 2012
    Byron, Michigan
    astroracer's Tools
    Thank You Sir! Yes, he did good. I think it transforms the whole interior! Once the new console is done it will look great!
    The original T-handle was okay but this puts it over the top.
    Yup, MUCH Better! I am also working on a little something to make it pop a little bit more...
    Thanks astroracer! We've added your Shifter Knob Adaptor to our Miscellaneous category, as well as to your builder page: astroracer's Homemade Tools. Your receipt:
