Results 1 to 6 of 6
Thread: Sheetmetal cutting roller - GIF
    mwmkravchenko (Feb 24, 2022), nova_robotics (Feb 23, 2022)
    Aug 2012
    Australia
    desbromilow's Tools
    two rollers acting like scissor blades?
  4. The Following User Says Thank You to desbromilow For This Useful Post:
    Perth Ontario Canada
    Quote Originally Posted by desbromilow View Post
    Yes. Two bearings ground on their sides to be sharp. And spaced apart enough to make them shear the sheet metal. This I will remember.
    Aug 2012
    Australia
    desbromilow's Tools
    Quote Originally Posted by mwmkravchenko View Post
    Thanks!!! I've never seen one drawn through the sheet like that, just the bench mount type where the sheet is pushed in, and the handle helps turn one wheel to keep things moving.
  7. The Following User Says Thank You to desbromilow For This Useful Post:
    mwmkravchenko (Feb 25, 2022)
    Pushed or pulled, same effect. The operation is known as 'slitting'.
    A foot (stomp) shear variety, known as a 'gap or 'C' frame' can also do this, still called slitting but mechanically works like a scissor.
    A foot (stomp )shear variety, known as a 'gap or 'C' frame' can also do this, still called slitting but mechanically works like a scissor.
    Yey. Worked on one of those. Haven't worked with one of these roller types. But my guess is once you get it cutting it should be fairly easy to cut and follow a line.
