Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Sheetmetal Brake full set plans & materias
    Supporting Member kess's Avatar
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    SheetMetal Brake Free full set Plans and materials.
    The basic plan is the same for the simple and the modified version.
    You can view the whole step by step building process at the previus three video parts.
    Part1
    Sheet Metal Bender Brake The Make (DIY) & First Use Stainless Steel BBQ
    Part2
    Sheet Metal Bender Brake Part2 (DIY) Sharpening the Edges of Brake Clamp
    Part3
    Sheet Metal Bender Brake Part3 (DIY) Fully Modified
  2. The Following 19 Users Say Thank You to kess For This Useful Post:
    astroracer (Feb 26, 2016), Christophe Mineau (Feb 22, 2016), clydeman (Jan 22, 2020), Diode2 (Apr 25, 2017), DIYer (Feb 23, 2016), Downeast Thunder (Mar 6, 2016), Jon (Feb 22, 2016), kbalch (Feb 22, 2016), lazarus (Jun 23, 2016), Majaha Mathem (Oct 3, 2016), Moby Duck (Oct 22, 2016), Neil Jensen (Feb 23, 2016), NortonDommi (May 4, 2018), Paul Jones (Feb 25, 2016), raceman61 (May 3, 2018), scoopydo (Feb 23, 2016), Tule (Dec 14, 2017), verticalmurph (Jan 22, 2020), voodoo59 (Aug 1, 2016)
    Thanks kess! We've added your Sheetmetal Brake to our
    Brakes and Presses
    category, as well as to your builder page: kess' Homemade Tools. Your receipt:
    kess (Feb 23, 2016)
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    How to get your own printable version.
    1. While you are watching the video at full screen, pause it at the desired point.
    2. Hit the Print Screen button on your keyboard.
    3. Open windows Paint or your favorite Photo Editor and hit paste or (Ctrl+V)
    4. Now you be able to print it
    or to convert it to (.pdf) file
    or to save as picture.
    Do the same at the rest desired points.
    Dec 2014
    Hi,
    Just wanted to say how much I enjoy Home Made Tools. I didn't realize it was a requirement to post a project in order to be a member of this forum. Remove me name if you must!
    Steve
  7. The Following User Says Thank You to sawswood For This Useful Post:
    dkrisatis (Jan 12, 2023)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Hi Steve,
    Welcome!
    No, it's by no means required to post a project, though we do like for each of our members to at least say hello. The camaraderie here amongst the builders in our community is a huge part (and a fantastic resource) of our essential character. So…
    What sort of homemade tools are your favorites? Are you working on anything at the moment?
    Ken
    Nice job I think i may build one. How much thickness will it bend
  10. #7
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Hi G.Paul,
    Welcome!
    What sort of project do you have in mind for the brake? Are you working on anything at the moment?
    Ken
  11. #8
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Hi G.Paul,
    The bigger bending thicknesses that I have tried without any problem:
    a. Simple version
    0.8mm stainless steel AISI 304 & AISI 430 at 800mm width
    1mm regular steel at 380mm width.
    b. Modified version
    1mm stainless steel AISI 304 at 800mm width
    The max useful capacity of this sheetmetal brake is 805mm (at both versions).
    The sheet metal on demonstration at part3 video
    is 0.90mm regular galvanized steel,
    the bending is 5mm from the edges, and I think that is a very good bending.
    (the smaller the height of bend the most difficult the job for the brake)
    Also keep in mind that Stainless steel needs about 4x more force per mm˛ than a regular sheetmetal steel to formulating.
    (I am not sure if I have used the correct terminology in English, but I believe you have understood what I mean).
    My needs till now, are only from 0.40~1mm at SS sheet metals,
    so I haven’t try it at bigger thicknesses yet,
    but I am sure that can do the job good enough for bending regular steel, aluminum, copper.
    At what thicknesses/materials plan to be use it?
    Regards
    Bill
  12. #9
    I have a home machine shop, every now and then i get into projects of metal bending. I like to be able to bend 10Ga tats why i asked what gage the brake can handle. I am also interested in a rod bender i can build.
    Thanks Kess
