Results 1 to 4 of 4
Thread: serration spline cutter
    john mullen's Avatar
    Feb 2015
    Lanexa Va
    I need help working out the details to make a cutter for splining a 1.250 shaft I want to use a serrated type of spline but I have no idea of what I will need as far as the number of splines that can be cut on that dia shaft I am also making a rotary broach to match the splined shaft. I will be using the tools to make custom sway bars for street cars and hot rods. any help or comments on this will be most welcome. Thanks, John
  2. #2
    Following this thread, and hoping to see a photo of the product, john muller.
    Feb 2015
    Lanexa Va
    I'm getting info on this project together and will be starting in a few days . I'll keep posting as I go
  4. #4
    I cruise threads by search terms. I ring in on many that many don't generate much input. If I was a presidential hopeful, that would build my constituency. However none of them know machine work, so...
    First we need what variety of splines are desired. Most prevalent are involute; yet others exist too. Theory - West Michigan Spline Next will be desired fit, permanent or part of an adjustment feature, and allowable clearance. An example are those on a motorcycle shifter shaft, minimal rotational clearance and locks with a binding bolt. Avoid a blind female socket. Size equals strength, heat treatable materials are more dependable.
    After deciding what materials will be used, next will be if the work is in-house or farmed out. You'll want good grade go/no-go gauges to monitor size in either case. For parts, most externals are rolled, and internals broached. Milling and grinding them are like single-pointing threads; tolerance control at labor intensive expense. Equipment is special purpose, large and pricey.
    The Machinists Handbook and Marks Standard Engineering give design guidelines based on torque calculations, of course the net is a vast but questionable library.
    Here, a google search for splined shafting turned up many results. I need a length, longer than travel of any mill I've access to, to repair an old drill press. Found material in one try.
    https://www.google.com/webhp?sourcei...Spline+shaft&*
