Results 1 to 6 of 6
Thread: Self-starting siphon - GIF
    Self-starting siphon.
    Shake starting a siphon - GIF
    U-shaped PVC siphon - GIF
    Simple irrigation siphon - GIF
    Shake-starting a siphon - GIF
  2. The Following 9 Users Say Thank You to Altair For This Useful Post:
    Biggus1942 (Apr 27, 2023), bob_3000 (Apr 27, 2023), mwmkravchenko (Apr 26, 2023), nova_robotics (Apr 26, 2023), piper184 (Apr 26, 2023), Ralphxyz (Apr 29, 2023), Rangi (Apr 26, 2023), Resident114 (Apr 26, 2023), tuchie (Apr 29, 2023)
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    OK, that is cool!
    May 2018
    Boring, OR
    CharlesWaugh's Tools
    Inertia seems to do the trick.
    Charles Waugh
    www.charleswaugh.com
    Supporting Member jzanter's Avatar
    Oct 2019
    Edgerton, Wisconsin
    can't quite see what's going on other than it appears to be a transient condition setup in the tube geometry before immersion?
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    Quote Originally Posted by jzanter View Post
    You have to shove a self-starting siphon, like that, into the water fairly quickly, which forces water up and over the first hump. On the backside of the first hump, gravity helps the situation, too, and accelerates the water (gives it more kinetic energy) to the point where it can shoot all the way up to the top of the second hump and over. At that point, it becomes a conventional siphon. As long as the outlet is below the water level in the container you're siphoning from, it will continue to run.
    You can accomplish the same thing with a conventional siphon by plugging the outlet, submerging the inlet side in the liquid you're siphoning, and releasing the plug. If you have the inlet deep enough and the hump leading to the outlet is close enough to the level of the surface of the liquid, the inrush of water will have enough force to rise above the liquid's surface and over the hump.
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
  7. The Following User Says Thank You to schuylergrace For This Useful Post:
    Aug 2018
    that_other_guy's Tools
    Got it!
    Sorcery.
