Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Self Locking Lathe Tool Height Adjustment
    Supporting Member hersch_tool's Avatar
    Nov 2023
    hersch_tool's Tools
    Hi all,
    Here's a quick and easy project where I made some "self locking" height adjustment knobs for my lathe's quick change tool holder.
    Thanks!
    Download plans for lathes.
  2. The Following 21 Users Say Thank You to hersch_tool For This Useful Post:
    57_210 (Dec 26, 2023), barnaby72 (Dec 20, 2023), bluegeezer (Dec 18, 2023), Bummers (Dec 24, 2023), davesrepair (Dec 18, 2023), ijs61 (Dec 20, 2023), johnreich (Dec 23, 2023), Jon (Dec 19, 2023), Metallurg33 (Dec 20, 2023), mr gadgets (Dec 20, 2023), mr mikey (Dec 18, 2023), nova_robotics (Dec 20, 2023), piper184 (Dec 19, 2023), Ralphxyz (Dec 22, 2023), RetiredFAE (Dec 18, 2023), rgsparber (Dec 22, 2023), schuylergrace (Dec 18, 2023), sossol (Dec 18, 2023), Tule (Dec 19, 2023), WmRMeyers (Dec 16, 2023), yair feldmann (Dec 19, 2023)
    Thanks hersch_tool! We've added your Lathe Tool Height Adjuster to our Lathe Accessories category,
    as well as to your builder page: hersch_tool's Homemade Tools. Your receipt:
    New plans added on 01/10/2025: Click here for 2,694 plans for homemade tools.
    hersch_tool (Dec 16, 2023)
    Supporting Member yair feldmann's Avatar
    Feb 2021
    Raanana, ISRAEL
    yair feldmann's Tools
    If the tool height is such that the locking screw faces the post, do you have access for Allen key?
  6. The Following 3 Users Say Thank You to yair feldmann For This Useful Post:
    rgsparber (Dec 22, 2023), tonyfoale (Dec 21, 2023), uv8452 (Dec 19, 2023)
    Oct 2019
    Germany
    uv8452's Tools
    Nice and impeccable workmanship. Permissible is what likes.
    But I would be annoyed by the nut's dead angle the allen key requires.
    Why not (e.g.) slit a larger ø nut laterally and clamp/brace it with an axial allen screw?
    We know this principle from 'playless' spindle nuts.
    Nov 2023
    hersch_tool's Tools
    Quote Originally Posted by yair feldmann View Post
    This is definitely the most asked comment on the video, and a great question.
    The short version is, no it's a design flaw for sure.
    However, it's not a show stopper.
    You can just lift up the tool holder to get access and tighten, or add a washer to clock it in a different location, etc.
    But the long version is, I'm gonna use these initial 3 for a little while taking note of this and any other issues I notice and then make a version 2.0 that addresses all of the issues in the future.
    I already have some ideas for the next version.
    Thanks very much for the watch and comment
  9. The Following 2 Users Say Thank You to hersch_tool For This Useful Post:
    cognitdiss (Dec 24, 2023), mr mikey (Dec 20, 2023)
  10. #6
    You sure were patient repeatedly answering that same point in the YT comments. It's a good demonstration of Cunningham's Law though.
  11. The Following User Says Thank You to Jon For This Useful Post:
  12. #7
    Sep 2018
    I to am frustrated by the current jam nut version. Seems to fiddly. So I hope to make a few of these for my most commonly used holder and see how it goes. Bet it goes much better than what is currently used. Basically, it's the answer to my problem. Thanks.
  13. #8
    Nov 2023
    hersch_tool's Tools
    Haha, I've never heard of that before, but it's 100% accurate.
    My wife said something similar, "I guess you can use YouTube as a way to check for flaws in your tool designs!" lol
    Always looking for the bright side.
    And yeah, I figure folks don't read other comments very often.
    And I'm just grateful that they watched my video and took the time to post a comment, so it doesn't bother me so much when I look at it that way.
    Cheers!
    HERSCH
  14. #9
    Aug 2021
    Cape Town SA
    albertq's Tools
    Hi Hersch, Thanks for sharing your tool height adjuster.
    With your tool height set precisely, how do you lock the adjusting ring if position of hex lock screw is hidden by tool-post lock handle?
    Or do you set the height to the closest 1/2 turn?
  15. #10
    Maybe I the odd one out here (it does seem to happen) but I see no problem with the as supplied version that can't be fixed by the removal of the washer between the two nuts. Lock nuts should jam together, a washer in between destroys that. Remove the washer and the system works fine.
  16. The Following User Says Thank You to tonyfoale For This Useful Post:
    Occasional machinist (Dec 22, 2023)
