Results 1 to 8 of 8
Thread: Selective soldering machine - GIF
    Selective soldering machine.
    Micro laser soldering - video
    Hair catches fire while soldering
    dubbby (May 19, 2020), KustomsbyKent (Mar 11, 2019), Scotsman Hosie (Mar 17, 2019), Seedtick (Mar 12, 2019)
    Supporting Member McDesign's Avatar
    Sep 2016
    McDesign's Tools
    does anyone still build thru-hole boards?
    Sep 2015
    Ontario Calif USA
    This does the whole board in one fell swoop.
    Not to out do Jon, just thinking about which came first.
    Jim
    Sep 2012
    Hinchinbrook QLD
    I dont know if that video is playing upside down or not?
    Supporting Member bimmer1980's Avatar
    Jan 2018
    bimmer1980's Tools
    I work in an industry where we buy a fair amount of thru hole PCB product. This is due to the performance and cost of the thru hole components.
    Selective soldering is neat to see. It is soldering on the underside of the PCB. The flow of solder is on a nozzle and the PCB is moved around to line up with the solder flow.
    Sep 2016
    McDesign's Tools
    Huh - I work in commercial/Industrial LED and drivers (Acuity Brands/EldoLED) - we've only ever done SMT.
  8. #7
    Sep 2017
    All I can say that I can't stand Lead Free soldering.
    At my work place we have 3 waves , 2 are regular lead and one is lead free. What a pita to set up. It solders totally differently. Lead is far more forgiving on running different thickness and thermal mass of the board then lead free.
    Side note: Foam Fluxer is before my time here but i was told that it was a POS.
    Also Thruehole components are now more expensive then SMT components. And now apperanlty you can't buy some of the "regular" SMT size components because the industry is going miniaturization and smaller components are now in. That means that my work place will have a hell of a time running 13 year old SMT machines.
  9. #8
    Sep 2016
    McDesign's Tools
    I bring my own leaded solder if I'm prototyping anything at work - lead-free does suck.
