Results 1 to 10 of 10
Thread: Security ground anchor
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    when my son did motocross I made a ground anchor for security to lock the bikes too. This anchor was built several years ago and have decided to reinstate it to secure other items and share the design.
    The main structure is made from steel with a commercially made eyebolt modified. The locking screws are protected with a aluminium cover which is held in place with three equally distanced M6 grub-screws. A wall plate is screwed to a solid surface and accepts four M6 socket headed screws to bolt the main body too. Even if the grub screws are removed from the aluminium the chain prevents the aluminium cover from being removed and exposing the M6 socket head screws holding the anchor together to the wall plate. This is a very heavy duty ground anchor.
    Photos showing installation of ground anchor:
    Security ground anchor-img_7634.jpegComplete assembly ready to be screwed to wall.
    Security ground anchor-img_7649.jpegWall plate screwed to wall.
    Security ground anchor-img_7635.jpeg Security ground anchor-img_7636.jpeg Main body of anchor. The bolt into the eye bolt is a shoulder bolt which allows the eyebolt to rotate.
    From the front, the four M6 socket head screws hold the main body to the wall plate.
    Security ground anchor-img_7650.jpegBolted to wall plate.
    Security ground anchor-img_7651.jpegAluminium cover in place shielding all bolts.
    A heavy duty chain and padlock enables items to be chained up. Perfect for securing expensive equipment in shed, garage, simply bolted to the floor or wall.
    Thank you for viewing
    The Home Engineer
  2. The Following 12 Users Say Thank You to thehomeengineer For This Useful Post:
    ductape (Jul 29, 2023), freddo4 (Aug 6, 2023), Inner (Jul 31, 2023), Jon (Aug 3, 2023), mr mikey (Jul 31, 2023), nova_robotics (Jul 31, 2023), Philip Davies (Aug 1, 2023), piper184 (Aug 1, 2023), rayh__ (Aug 1, 2023), Toolmaker51 (Jul 31, 2023), trevor_60_r (Aug 7, 2023), Tule (Aug 1, 2023)
    Dec 2022
    Midwest US
    ductape's Tools
    Very good design. Given enough time, most physical security devices can be defeated. Your method is to make it so tough and frustrating that the offender realizes that it isn't worth the effort, and that works more often than not.
    Last edited by ductape; Jul 29, 2023 at 06:41 PM. Reason: Sometimes, one word is better than another.
  4. The Following User Says Thank You to ductape For This Useful Post:
    thehomeengineer (Jul 30, 2023)
    Thanks thehomeengineer! We've added your Security Anchor to our Miscellaneous category,
    A floor anchor is a far more inviting target; all kinds of things might generate force to defeat it. Less so on a resilient wall, some of those methods much harder to employ.
  7. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    thehomeengineer (Aug 1, 2023)
    Dec 2017
    NeiljohnUK's Tools
    Cordless grinders however are cheap, and effective, so as many locking points and separate chains as possible are required. My favoured ground anchor design uses thick wall box 2" section steel, cut at 45 degrees to make it safer to roll a vehicle over, long enough for 2 or 3 rawl anchors (bolt type) that are tightened through 1" holes through the top, pass the chain through and you can't undo the bolts. Cheap and reasonably effective for most things, multiplied to delay thieves so they have to cut several chains, then U locks, then difficult to access padlocks on the cast spokes of my road bikes. Such are the joys of living in an English town these days...
  9. The Following User Says Thank You to NeiljohnUK For This Useful Post:
  10. #6
    Berkshire UK
    I think all mechanical security systems no matter how good they are or what insurance criteria they meet, they are more of a visual and nuisance deterrent than preventive. If a thief wants it bad enough they will find away. The emphasis is on the owner to make it as difficult as possible so they just move on. Unfortunately, onto their next victim. Cameras are very good as we have these at home, we will eventually install cameras at this property. But correct me if I am wrong, camera systems rely on power the internet or recording equipment to be successful. I know you can buy dummy camera's.
  11. #7
    Dec 2017
    NeiljohnUK's Tools
    Camera's are no longer a deterrent, as the thieves know the Police won't even bother looking at the recording in many areas of the UK, unless your obscenely rich or well connected. In many cases it's just seen as a 'flag' you have something worth stealing, one of the advantages of the ubiquitous Ring doorbell cam's is everyone's got one in many places, so less 'flag' effect, though you have to be careful where they can see:
  12. The Following User Says Thank You to NeiljohnUK For This Useful Post:
  13. #8
    Congratulations thehomeengineer - your Security Anchor is the Homemade Tool of the Week!
    Simple wins it this week, and this design offers a lot of protection. Along with your Security Post, these are two good solutions for deterring theft.
    Rattle by Stevohdee
    Machinist's Jack by Improvised DIY
    Plinth Hoist by Mr. Factotum's Workshop
    Articulated Arm Mount by Bricoleando
    Tool Rest Adaptor by hemmjo
    Dual Power Disc Sander by Didpoolhall
    Adjustable Roller Support by orioncons36
    Miter Saw by AB-SHOP
    Drill Bit Sharpening Guide by orioncons36
    thehomeengineer - you'll be receiving a $100 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    This is your 12th Homemade Tool of the Week. Here are all of your Homemade Tool of the Week winning tools. Congrats again
  14. #9
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    The anchor may be strong but the concrete block it's attached to is the weak link.
  15. #10
    Berkshire UK
    Hi Jon
    Thank you again and to all who read the post.
    The Home Engineer
