Results 1 to 5 of 5
Thread: Screwdriver bit sorting machine - GIF
  2. The Following 5 Users Say Thank You to Altair For This Useful Post:
    desbromilow (Dec 13, 2021), FEM2008 (Dec 18, 2021), johncg (Dec 19, 2021), nova_robotics (Dec 13, 2021), Toolmaker51 (Apr 11, 2022)
    re post *1
    These mechanisms are tremendous factor in assembly and packaging. So, there has to be specialists in vibratory bowl feeders, right?.
    With slightest degree asymmetrical, doesn't seem any limit to what will feed and sort. Screwdriver bits, tacks, screws and nails, cartridge cases, bottle caps, rivets, brackets and other stampings..., large or small. Many in use long before CAD drawings, CGI, or any type of virtual electronic imaging.
    So, what kind of hardware littered desks of these specialists; toying with how to feed so and so?
    Not everything can be solved with just a cocktail napkin!
    NortonDommi (Apr 12, 2022)
    re post *1
    No sometimes it takes 2 napkins
    Are they edge-glued like note pads?
    Only when 4 or more are required to make a 4, 6,9 or 12 napkin sized drawing a 12 size is larger than an E sized
