Results 1 to 10 of 12
Thread: Screw vise with a hydraulic jaw
    Jyväskylä Finland
    Tuomas's Tools
    This is my second prototype about vise that can be used with a screw or hydraulic jack.
    This design gives wider opening than "regular" hydraulic vises.
    Preview about the use:
    Actual video below.
  2. The Following 14 Users Say Thank You to Tuomas For This Useful Post:
    baja (Jun 12, 2020), Beserkleyboy (Jun 12, 2020), Carnel (Jun 12, 2020), Dimsa (Jun 15, 2020), Gregraper33712 (Jun 12, 2020), Jon (Jun 12, 2020), Moby Duck (Jun 11, 2020), mr mikey (Sep 20, 2024), mwmkravchenko (Jun 12, 2020), Paul Jones (Jun 24, 2020), Ralphxyz (Sep 28, 2024), sossol (Jun 11, 2020), Toolmaker51 (Jun 15, 2020), Tule (Jun 12, 2020)
    Jyväskylä Finland
    Tuomas's Tools
    Here is the video:
    (uploaded wrong version first, sorry)
    Materials 12-25mm steel and LDX 2404 ( lean duplex ) for the jaw guides.
  4. The Following 4 Users Say Thank You to Tuomas For This Useful Post:
    Jon (Jun 19, 2020), mr mikey (Sep 20, 2024), Ralphxyz (Sep 28, 2024), Toolmaker51 (Jun 15, 2020)
    CanBeDone's Avatar
    Oct 2019
    To have the adjustability of the vise and the force-capability of a hydraulic press in a single tool - fantastic!
    Don't delete the first video - just re-label it as "Capability" - it tells what your gizmo can do what neither a vise nor a hydraulic press are capable on its own, but what can be achieved when melding them into a single tool.
    Do I see it right - as constructed the vise is capable of 2 tons of force?
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by CanBeDone View Post
    Thank you.
    Yes, its a 2 ton jack / press.
    Return springs are from a scooter front shock absorbers, those are somewhat strong and possible limits the max power to 1,8 - 1,9 ton.
    Other materials: 12-25mm steel and LDX 2404 ( lean duplex ) for the jaw guides, 22mm dia rods and 30mm x 35mm squares.
    Thanks Tuomas! We've added your Bench Vise to our Vises category,
  9. The Following User Says Thank You to Tuomas For This Useful Post:
    Jon (Jun 17, 2020)
  10. #7
    Congratulations Tuomas - your Bench Vise is the Homemade Tool of the Week!
    Another big week around here, but it's hard to beat one of Tuomas's unique vises, and this is his 4th vise that has won this award.
    Heat Treatment Oven by anthonyget
    Hand Plane Storage Till by Brendon
    Mower by th62
    Drill Sharpening Jig by th62
    Optical Center Punch by th62
    Sheetmetal Filing Clamp by editor@glue-it.com
    Non-Electricity Tool Plating Method by Kovanca Polock
    Sheetmetal Bending Calculator by rgsparber
    Rebar Bender by fawabros
    Manometer by th62
    Angle Grinder Cutting Guide by olderdan
    Pocket Hole Jig by rendoman
    Internal Boring Tool by machining 4 all
    Bender by daniels1186
    Handle Broach by JKeetonKnives
    Horizontal Bandsaw Precision Cutting Fixture by rgsparber
    Tool Panel by Bricoleando
    Captured Nut Replacement Method by theeddies
    Mill Crank Thumb Wheel by craig9
    Lathe Tool Holder by bobs409
    Benchtop Grinder by HandmadeCreativeChannel
    Adjustable Miter Sled by Christofix
    Boring Head by kwm24@o2.pl
    Silent Air Compressor by Mr.DK DIY
    Sharpening Jig by Mazay
    Lathe Cooling Pump by celsoari
    Branding Iron by bstanga
    3D Printer Cabinet by bobs409
    Cyclone Swarf Collector by bouboulas
    CNC by rep
    Table Clamp by Kwandotechnic
    Tuomas - you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    This is your 12th Homemade Tool of the Week win. Here are all of your Homemade Tool of the Week winning tools. Congrats again
  11. The Following User Says Thank You to Jon For This Useful Post:
    Tuomas (Jun 20, 2020)
  12. #8
    Jyväskylä Finland
    Tuomas's Tools
    Thank you very much Jon.
  13. #9
    Aug 2016
    wizard69's Tools
    Well Thank You for the excellent video and frankly a fantastic idea for a bench vise!!!! I' not sure if you follow but the guy running Fireball tool just did a vise build that also is of great interest. Lots of vise building and reconditioning, going on this year.
  14. #10
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by wizard69 View Post
    I haven't watched it, but watched now that you mentioned.
    This is somewhat same sized 40cm opening = 16".
    That allows to use bending dies, installing bearings to longer axles... Etc
    " Regular " hydraulic vise opens 4-6" That's not very much, and doesn't allow to use nearly more that just clamping objects. That's why i started to think about option that allows to get the advantage about the hydraulic use. Otherwise there wouldn't be much difference, if the vise is screw or hydraulic powered, if it can't be used more than holding objects.
