Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: Screw-on chuck mounting to bayonet.
    Get an eyeful of those ways, NO scrimping there!
    Later years then US heavy iron, Italy, Spain, Britain, areas around Poland, Czechoslovakia, likely Russia too, had no hesitation building heavy patterned machine castings. I'm sure the iron was of good specification like Meehanite, chilled, seasoned, induction hardened as measures of competition...
    My old Spanish lathe did not have hardened ways hence the wear problem. There are times when I wish that I still had that machine for heavy work despite the wear. Did you notice the interesting feature of the ways? The tailstock had the normal - one flat/one pyramid - arrangement but the saddle had two pyramids.
    I kept a lot of things when I scrapped that lathe and many have been put to good use. Several featured in my past posts.
    The motor and gearbox were kept, of course. The motor was used to power my shock dyno; Shock dyno (or Shock absorber dynamometer)
    The face plate and chuck back plate are used in this chuck mounting post.
    Mounted on a square steel plate the chuck is used on the mill as a vice for round things.
    I kept the cross slide and compound rest which was used in my brake drum grinder; Grinding machine for drum brakes.
    The cylinder from the tailstock was the basis of my cylindrical square; Cylindrical square from a lathe tailstock.
    The lead screw was used to make the boring bar for a line boring setup that I used to make front forks.
    Reusing madness.
    Download plans for chucks.
  2. The Following User Says Thank You to tonyfoale For This Useful Post:
    Toolmaker51 (Feb 16, 2021)
  3. #12
    Reusing madness? Madness is not re-use.
    Can't plan where every part may wind up; recalling them generates visualization.
    It's only scrap when you cant devise a way to hold it.
  4. #13
    Recalling anything is my problem.
  5. #14
    Apr 2012
    NorCal
    Saltfever's Tools
    (edit. . . much deleted) I kept the cross slide and compound rest which was used in my brake drum grinder; Grinding machine for drum brakes.
    Some great links but an important one is missing! I'm very interested in seeing your line boring setup. A write up can be tedious and time consuming, so I am not making that request, but maybe a couple of pics for the curious!
    I have been thinking about the drive mechanism for such a machine but have made no progress. Visions of an Arduino/stepper/Mach III machine have languished as being too complicated for such a simple machine and flown off into the ether! I am now considering a Power Table feed accessory as a possible way to drive a lead screw. I would be interested in your thoughts.
  6. #15
    Apr 2012
    NorCal
    Saltfever's Tools
    (edit . . . )
    Attachment 38495
    Some years ago I had a very old and worn lathe which had a "bayonet" chuck fitting.
    As always, an excellent presentation and high quality content. I find the Bayonet interesting but was not aware of it. I have never seen one, or the adaption to other types of machine tool work holding in the US, except in optics. All the best . . .
  7. #16
    OK, but just for the curious.
    Screw-on chuck mounting to bayonet.-boring-fixture21.jpg Screw-on chuck mounting to bayonet.-obviouslyitalian.jpg Click for full size.
    The end result was making some 1960/70s replica front forks.
    It depends on what you want to do with it. If you want uncoordinated axis moves then the unit that you mention would be fine. If you want to coordinate the moves on different axis then steppers would be the easiest solution.
  8. The Following 2 Users Say Thank You to tonyfoale For This Useful Post:
    DIYSwede (Feb 22, 2021), olderdan (Feb 22, 2021)
  9. #17
    I found another pic which shows what it was that I line bored.
    It was the tube in the middle of this photo.
    Screw-on chuck mounting to bayonet.-dsc_3219.jpg Click for full size.
  10. The Following User Says Thank You to tonyfoale For This Useful Post:
  11. #18
    olderdan's Tools
    Tony,
    Beautiful work on those fork sliders, stronger than the originals no doubt and some special internals maybe? I understand the line boring fixture having done similar in the past on roadholders and good use of an old leadscrew. I would be very interested in your machining sequence to the bottom spindle mountings.
    Regards
    Alan
  12. #19
    Tony,
    Regards
    Alan
    Ha, I cheated. I bought some Honda forks from a wreakers because I wanted the so called cartridge inners. A bit of measuring showed that a bit of cutting and turning could transform the sliders into Ceriani look alike bottoms.
    I'll try to find the time to make this a full post but this should give you the idea.
  13. #20
    Apr 2012
    NorCal
    Saltfever's Tools
    OK, but just for the curious. (edit . . . ) If you want uncoordinated axis moves then the unit that you mention would be fine. If you want to coordinate the moves on different axis then steppers would be the easiest solution.
    Thanks for getting back to me, Tony. I just need just single axis travel for doing main bearing caps in a block. I will be replacing OEM cast iron caps with (yet to be designed) DIY 4140 caps. I would like to use carbide inserts but bar deflection, and high rpm may change those thoughts. Only collecting good ideas at this point . . . haven't had time to do anything else.
