Results 1 to 10 of 10
Thread: sawing thin aluminum angle stock, round 2
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Collaboration is a wonderful thing. After people saw my last video on this subject, many great suggestions were made. The result is a far simpler way to cut thin aluminum angle stock:
    Rick
    Download plans for bandsaws.
  2. The Following 20 Users Say Thank You to rgsparber For This Useful Post:
    Altair (Dec 21, 2014), Andyt (Jun 3, 2020), asterix (May 24, 2022), baja (May 26, 2022), Carnel (Jun 3, 2020), Corm (Mar 24, 2018), dietmar g (May 24, 2022), H.L (Oct 14, 2015), Inner (Jun 3, 2020), kbalch (Dec 22, 2014), KennethAndré (Oct 17, 2017), kngtek (Oct 17, 2017), oldcaptainrusty (Oct 18, 2017), Paul Jones (Dec 21, 2014), RetiredFAE (Aug 30, 2024), rlm98253 (Oct 16, 2017), thehomeengineer (Jan 15, 2018), uv8452 (Nov 8, 2023), wb8nbs (Oct 19, 2017), winmac (Jan 19, 2023)
    Thanks for the tip Rick! Never thought of using a sacrificial block.
    Al
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    You use the block to support the angle stock but it is set back so the blade does not hit it.
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Rick,
    What a great idea! This opens up a whole new way for us to easily cut thin walled metal structures.
    Thank you for the update,
    Paul
    Yes, this idea is much better, and a piece of wood is more readily available.
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Rick! I've added your Aluminum Angle Cutting to our Bandsaws category, as well as to your builder page: Rick Sparber's Homemade Tools. Your receipt:
  8. #7
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    This thread has been moved to the Must Read subforum. Congrats (and thanks) to Rick for making such a valuable contribution!
  9. #8
    wb8nbs's Avatar
    May 2017
    That should work on tubing as well. Insert a snug fitting dowel rod before cutting.
  10. #9
    Dec 2016
    Ralphxyz's Tools
    gotta keep this in mind, thanks for posting.
    Ralph
  11. #10
    Supporting Member Unisawyer's Avatar
    Jan 2018
    Canada
    Unisawyer's Tools
    Thanks!. You could also title this "how to save time , money, and eliminate frustration". I am going to make one now. Cheers.
