Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Saw not cutting stright
    Berkshire UK
    thehomeengineer's Tools
    Again well worth a watch thank you
  2. The Following User Says Thank You to thehomeengineer For This Useful Post:
    Paul Jones (Feb 2, 2018)
  3. #12
    Supporting Member pfredX1's Avatar
    Sep 2016
    Delaware
    pfredX1's Tools
    My 4x6 may not cut stock too square but it cuts stock more square than I can.
  4. The Following User Says Thank You to pfredX1 For This Useful Post:
    thehomeengineer (Jun 2, 2018)
  5. #13
    Sep 2018
    A bandsaw blade which is perfectly adjusted to the table can still wander to one side if the set of the teeth is not exactly even on both sides of the blade due to a manufacturing inaccuracy, or uneven wear of the teeth. I adjust my bandsaws so that they cut square, not so that they are square to the table.
  6. The Following 3 Users Say Thank You to johnsmachines For This Useful Post:
    Jon (Oct 5, 2018), Paul Jones (Oct 17, 2018), Toolmaker51 (Oct 4, 2018)
  7. #14
    Sep 2013
    Karl_H's Tools
    I use a small neodymium magnet to hold the 6 inch rule against the blade. However, this makes the rule magnetic, which causes it to attract to the square.
    My solution was to make an aluminum square.
    I used a piece of 1/4 inch aluminum, and "eye balled" it square on the mill table and clamped it tight. Without moving the blank, I squared up the two sides to the accuracy of the x & y axis of my mill.
