Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: Sailing a boat under a bridge - GIF and video
    olderdan (Nov 16, 2017), Rangi (May 4, 2020), Seedtick (Nov 16, 2017)
    How do they right the boat after motoring under the bridge? I doubt they have ballast tanks and, even if they did, couldn't transfer that quickly.
  4. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    olderdan (Nov 16, 2017), Toolmaker51 (Sep 30, 2018)
    olderdan's Tools
    It looks like they pulled the weights inboard so the craft rights itself, its a shame we dont get to see how they swung them out in the first place. It takes a lot of confidence to pull a manoeuvrer like that.
    OK, I missed that. If you look really, really closely you can see the lines attached to the bottom of the weights. These must be what they use to retrieve the weights. As you say, it takes a lot of sailing expertise to perform such a maneuver.
    Jan 2016
    Moby Duck's Tools
    They are possibly water bags. Secure bags to a mast top rope, dangle over the side, fill with a hose or bucket, (or just dip them), hoist bags slowly when full and they should give the required list if you got the calculations right. On completion, haul bags inboard and spill water on deck.
    This is a well thought out maneuver but this yacht is not 'sailing' under the bridge, it is 'motoring'.
  8. The Following 2 Users Say Thank You to Moby Duck For This Useful Post:
    olderdan (Nov 17, 2017), Toolmaker51 (Sep 30, 2018)
    Here's a fail of a boat under a bridge. The mast breaks once about midway up, and then either breaks or detaches at the deck. Is this the correct designed failure for the mast?
  10. The Following 2 Users Say Thank You to Jon For This Useful Post:
    markonevet (Oct 6, 2018), Seedtick (Oct 6, 2018)
  11. #7
    The best failure mode would be for it to break in such a way as to land on the head of any boat driver dumb enough to sail under a descending lift bridge.
  12. The Following User Says Thank You to mklotz For This Useful Post:
  13. #8
    Evidence of a common nautical failure "Failure to maintain a proper forward watch". Often coupled with a case of too much money, or it being collected too easily.
    How does one take the helm unaware proper info on his draft, mast height and periodic tide? I'd guarantee bridge supports are marked for any tide that harbor receives.
  14. #9
    Nov 2015
    A very expensive day. Gives meaning to BOAT (Break Out Another Thousand).
  15. #10
    The same quality of people would be the one who try to outrun the RR crossing arms as they are descending their judgement is clouded by the incurable disease of stupidity.
