Results 1 to 4 of 4
Thread: Router Table to Nibbler Table
    May 2012
    Byron, Michigan
    astroracer's Tools
    I've had this Rodman Sheet Metal Nibbler for years. It works well and it gets used but it is a bit uncontrollable when hand held and only a bit better when clamped to the bench.
    I saw a post on here on Homemade Tools where a guy built a box to mount his and thought that would be the berries. I never pursued it though, until yesterday.
    I got to thinking, I don't need a huge box for this thing, just something big enough to be able to support the sheet I am working with. I thought a little table would be perfect. I have one of those Cheapish Craftsman router tables, aluminum top with sheet metal legs... Hmm.
    I dug it out and took off the router and fence and started designing.
    This is the underneath where the router bolts up.
    I made a plug out of 1/2" plywood as a spacer.
    Continued in next post.
  2. #2
    May 2012
    Byron, Michigan
    astroracer's Tools
    Drilled the three holes for screws and made a base plate to mount the nibbler to.
    The notch at the top captures the bottom of the table, at the rear, where the blade guard/dust collector attaches. I wont be using any of that for the nibbler version.
    With the base plate made and attached I got the mounts for the nibble made. This is simply two pieces of 3/4 lumber screwed to the base plate from the top.
    This clamps the nibbler mounting head between the wood with that 3/8th's bolt. It is very stout, during test runs the nibbler didn't bounce or vibrate at all.
  3. The Following User Says Thank You to astroracer For This Useful Post:
    PJs (Jan 22, 2017)
    May 2012
    Byron, Michigan
    astroracer's Tools
    Getting the drill motor attached was pretty easy. I chucked it up to the drive post on the nibbler and strapped in place with a piece of pipe hanger. Didn't even have to drill holes, they were both there.
    Looking from underneath.
    It worked well on a couple of quick test samples. We'll see how it does on a real world job.
    This whole mess come out with 5 screws if I need to actually use the table as a router table.
  5. The Following 2 Users Say Thank You to astroracer For This Useful Post:
    Paul Jones (Jan 22, 2017), PJs (Jan 22, 2017)
    Thanks astroracer! We've added your Handheld Nibbler Mount to our Metalworking category,
    as well as to your builder page: astroracer's Homemade Tools. Your receipt:
