Results 1 to 10 of 20
Thread: Router lift
    logger6010's Avatar
    Jul 2013
    Cornwall . United Kingdom
    Router lift
    Hi guy's
    I'm in the process of make a Router lift
    I have looked online at different homemade tool sites but making up my mind on which one to make
    so can anybody please advise the best to make
    Many thanks Logger6010
  2. #2
    Sep 2016
    Currently i'm in the process to design a routerlift. If this one is a success, I promish you to contact you.
    Apr 2016
    kiwiles's Tools
    https://www.woodgears.ca/router_lift/plans/index.html
    he also has one for a tilting one as well
    les
  4. #4
    logger6010's Avatar
    Jul 2013
    Hi guys
    Thanks for your messages and I can't wait for any further info
    that you come up with
  5. #5
    Apr 2016
    kiwiles's Tools
  6. The Following User Says Thank You to kiwiles For This Useful Post:
    C-Bag (Oct 24, 2016)
    Nov 2015
    Router lift.
    Quote Originally Posted by logger6010 View Post
    Hi guy's
    Hey I would look at pinterest website or app. They have a ton of ideas.
  8. #7
    Nov 2013
    Georgia
    I was able to mount my Ryobi R-600 to a table and used a piece of 3/8-16 all thread, a coupling nut, a hex cap screw and a t-nut for the lift. All that replaced the adjustment knob, shaft, etc.
    Works a treat.
    Thom
  9. #8
    buildwithwood's Avatar
    Nov 2015
    I don't have any info on this subject; I have 2 Bosch routers that have acces through the plate, for a hex wrench that lifts the router. It seems to work real well.
    Good luck with your project.
  10. #9
    Sep 2015
    Utah
    I jut used an old scissor jack from a trailer. It works very well. It was cheap and on hand. I just turn the handle a little bit and it will raise the router and opposite direction takes it down. I have a flat board bolted to the Jack so it goes up against the bottom of the router. It takes up very little room in my cabinet. It works on every router I have. To make sure it stays in place, I use different diameters of PVC pipe. I drilled two hole in the PVC, place nut on the inside and the outside of the pipe that will screw against the router. This way nothing can move while working. This works like a st screw To Change up or down, yes I have to undo the bolts, 30 seconds or less. Works very well.I thin because of the jack I actually have more adjustments than a lot of store bought lifts.
  11. The Following User Says Thank You to Tagwatts1 For This Useful Post:
    Willworkfortools (Jan 9, 2018)
  12. #10
    logger6010's Avatar
    Jul 2013
    Hi guys
    Thanks your ideas are varied and don't cost a lot
    also the scissor jack is a great idea
