Results 1 to 6 of 6
Thread: Rotating head copper tubing cutter - GIF
    Rotating head copper tubing cutter.
    Copper pipe press tool- GIF
    Copper tube expander - GIF
    Ratcheting tubing bender - GIF
    Copper pipe deburring tool - GIF
    Swaging a copper pipe - GIF
    nova_robotics (Mar 19, 2022)
    No thanks, I'll stick with my ridgid 29963 cutter At least it won't ever have a dead battery. and I can cut stainless with it
    Tonyg (Mar 20, 2022)
    Supporting Member bob_3000's Avatar
    Aug 2020
    It's only a hundred bucks, fits in a wall cavity (hand held can never do that), I know how to plug in a battery charger, I just ordered mine.
    Quote Originally Posted by bob_3000 View Post
    I'll give you that, plus I can see where a tradesman doing new construction would benefit in the labor savings on a daily basis especially if it had a built in debur and/or swedging attachment, but that might be self defeating from the added bulk. For someone like me who rarely does copper plastic or aluminum not so much.
    I mostly do stainless hydraulic tubing and Milwaukee may offer cutter wheels for stainless I haven't checked.
    For the odd times when I have to do wall cavity work I have an old one of these
    Rotating head copper tubing cutter - GIF-40617_ridgid_101-close-quarter-cutter_side-left_72dpi.jpg
    Mine though is about 30 years old and it will fit in my pocket
    Oct 2016
    old kodger's Tools
    It's all very well cutting pipe in a wall cavity, but then you have to get in there to join it to something else.
    Dec 2017
    NeiljohnUK's Tools
    https://www.bes.co.uk/kopex-pipeslic...ter-15mm-7763/ and add a motor?
    I have mini 1/8" through to 6" conventional cutters like the Ridgid Frank S pictures above, though I mainly use a Swagelok one for s/s tube work.
