Results 1 to 4 of 4
Thread: Rotary Welding Stand - Foot Operated
    Supporting Member brianhw's Avatar
    Dec 2015
    brianhw's Tools
    Hi all,
    Having to occasionally weld flanges to tubing etc., for small jobs, I decided to make up this simple stand using my readily available scrap materials.
    With advancing age and an increasingly unsteady hand, this makes this process much easier. Not having to walk round the job with the welding torch and its cable trailing behind or having to stop and rotate the work, is a real boon. Could also be used for spraying car wheels with the same benefits.
    There is nothing sophisticated like bearings being used, the outer tube simply turning metal to metal at the top, making a good earth/ground contact.
    There is about 1/8 to a 1/4 inch of vertical clearance between the two discs to allow freedom of movement.
    Download plans for rotary tables.
  2. The Following 27 Users Say Thank You to brianhw For This Useful Post:
    baja (Jan 2, 2019), biggist (Oct 18, 2024), bruce.desertrat (Nov 10, 2017), Captainleeward (Nov 9, 2017), clydeman (Feb 13, 2023), dwbachor (Nov 7, 2017), Floradawg (Mar 12, 2024), gunsgt1863 (Nov 8, 2017), HobieDave (Apr 12, 2020), Jon (Nov 10, 2017), Komo (Apr 14, 2018), mccwho (Feb 15, 2023), mwmkravchenko (Jan 1, 2019), n9dug (Oct 3, 2020), nova_robotics (Jan 28, 2022), oldcaptainrusty (Nov 7, 2017), rlm98253 (Apr 8, 2018), Seedtick (Nov 7, 2017), Sleykin (Nov 9, 2017), Sprig1 (Nov 8, 2017), that_other_guy (Jan 29, 2022), thehomeengineer (Apr 9, 2018), Themadone (Dec 15, 2017), Toolmaker51 (Nov 7, 2017), tuchie (Feb 13, 2023), verticalmurph (Oct 2, 2020), yhprum (Jan 8, 2022)
    Thanks brianhw! We've added your Rotary Welding Stand to our Welding category,
    as well as to your builder page: brianhw's Homemade Tools. Your receipt:
    Dec 2016
    Ralphxyz's Tools
    Nice!!
    Thanks!!
    I have a couple of brake disks that I have had for 20 years waiting for a use. Now I can see it.
    Ralph
    Mar 2012
    yhprum's Tools
    I like the idea. I am afraid the cat lost one life there though.
