According to Phase-A-Matic, Inc.
Due to the high in-rush current required to start a motor (5 to 10 times the normal running
current), most applications require sizing the HP of the Rotary Converter 50% larger, or
more than the horsepower of the largest motor, or any combination of motors started at
exactly the same time. The first motor started, if not running heavily loaded, generates
additional 3-phase power back into the circuit. You can then run additional motors provided
they do not run heavily loaded and are not started at the same time. A maximum of up to 3
times the HP rating of the Rotary Converter can run at the same time - if not heavily loaded,
and not started simultaneously. For example, a 30 HP Rotary Converter potentially could
run motors totaling up to 90 HP.
