Results 1 to 1 of 1
Thread: Rotary Air Engine
    Apr 2017
    UK
    editor@glue-it.com's Tools
    Rotary Air Engine
    Hopefully this short video shows how the rotary engine works in terms of the conrods.
    In rotary engines the crankcase rotates with the propeller. The conrods rotate about the crank pin. These two rotational axes are parallel and half the length of the stroke apart. In this way the early engines removed the need for a heavy flywheel by using the mass of the engine as rotational inertia.
    Making the 5 cylinder rotary engine
  2. The Following User Says Thank You to editor@glue-it.com For This Useful Post:
    rdarrylb (Oct 2, 2021)
