Results 1 to 5 of 5
Thread: Rope drive engine
    Rope drive engine
    This is my version of Elmer Verburg's rope drive engine. Two double acting cylinders are connected to the flywheel with 90 degree quadrature so the engine is self-starting. A common manifold feeds air/steam to the cylinders through a valve controlled by the functional governor.
    The rope is a single loop of heavy gauge packing, three strand twine. (Splicing twine is a very tedious job.) The grooves on the flywheel and layshaft pulley are parallel. (Many people assume they must be threads.) The idler uses a weight to take up any slack in the rope due to moisture, etc.
  2. The Following 11 Users Say Thank You to mklotz For This Useful Post:
    Hemi (Sep 26, 2018), JD62 (Apr 24, 2017), jjr2001 (Nov 4, 2016), Jon (Apr 11, 2016), kngtek (Apr 25, 2017), KustomsbyKent (Apr 24, 2017), lazarus (Jun 5, 2016), PJs (Apr 11, 2016), ranald (Jan 6, 2019), Seedtick (Apr 25, 2017), Toolmaker51 (Sep 25, 2018)
    Supporting Member jotasierra's Avatar
    Sep 2015
    país Argentina, provincia de San Juan
    jotasierra's Tools
    Una joya Mklotz, felicitaciones.
    jjr2001's Tools
    That is amazing. Two pistons and all that rope running in perfect order. Love it.
    Cheers, JR
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    Neat, Like the way the rope is transferred back to the beginning of the run.
    Quote Originally Posted by Hans Pearson View Post
    And it's functional, too. Rope drives suffered in damp conditions when the rope would stretch and thereby lose traction. Incorporating the pulley loaded by the dangling weight provided an automatic tensioning device that took up the slack and kept the rope transmitting power.
  7. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    Hemi (Sep 26, 2018), Toolmaker51 (Sep 25, 2018)
