Thread: Rolling base and motor mount for 20" woodgears bandsaw
    Supporting Member craig9's Avatar
    Jul 2019
    Hobart, Tasmania
    craig9's Tools
    Lightbulb Rolling base and motor mount for 20" woodgears bandsaw
    Hi all,
    For a while now my home made bandsaw has been clamped to a furniture dolly, at the wrong height, and with a temporary 1/2 hp motor clamped to the frame.
    In the following two videos, I get the base and casters sorted, and I manufacture and fit a steel motor mount for my replacement 2hp motor, from some old C channel.
    Base and casters:
    Motor mount:
    If you look back through my past videos, you can also find the videos where I modify the rotor of the replacement motor, to turn off the threads, build up the shaft, and then slot it for a keyway, and make a keyed pulley to suit.
    Next up on the bandsaw build is lower enclosure and then finishing with paint on the bare steel, and oil on the bare wood.
    Cheers,
    Craig
  2. The Following User Says Thank You to craig9 For This Useful Post:
    rlm98253 (Jul 28, 2020)
    Thanks craig9! We've added your Bandsaw Base to our Bandsaws category,
    as well as to your builder page: craig9's Homemade Tools. Your receipt:
