Results 1 to 4 of 4
Thread: rivet nut tool
    rivet nut tool
    Hi,
    l am looking for cheap homemade rivet nut installation tool
    Regards
  2. #2
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Hi kgenterprises,
    Welcome!
    Have you seen these: Rivnut Tools
    It's dead simple to cobble something adequate together from a bolt and a couple of nuts/washers, especially if you're only doing a few aluminum rivnuts. If you need to install a large number, or if you're using steel rivnuts, then you'll likely need a sturdier tool. Depending on where you're planning to use them, you might even do better with nutplates.
    What are you building?
    Ken
  3. The Following User Says Thank You to kbalch For This Useful Post:
    PJs (Sep 22, 2015)
    Hi kgenterprises - welcome to HomemadeTools.net
    Hi kgenterprises, as Ken has pointed out, you'll find a ton of rivnut tools here. You're likely to find one that suits the materials you have on hand. Welcome to the forums!
