Ripping motor windings from housing.
Coil winding machine - GIF
40MW generator winding - photo
Automatic armature winding machine - GIF
Armature winding machine - GIF
Toroidal coil winding machine - GIF
New plans added on 10/16: Click here for 2,513 plans for homemade tools.
johncg (Oct 27, 2021), nova_robotics (Oct 26, 2021), rlm98253 (Oct 27, 2021)
Having rewound a few motors I can say for a fact that those windings came out a lot faster than they went in.
You might note how even the ends are. That tells me they were cut on the other end before puling them out , other wise they would not come out with 1 pull.
lassab999 (Oct 26, 2021), Philip Davies (Oct 30, 2021)
i got a bare axe head, and spent some time w angle grinder, thinning it out ,, so its long and thin,,,use a 5# hammer and 20-25 hits later its in half,,,currently working on a hydralic press, using a 1/4 plate sharpened on one end to cut in half..its very easy using a 20 inch pry bar to remove stator wire once u split in half..now the small stators, where the plates are shorter that 2 inches i leave alone and use a chisel to cut off one end of wire ,then remove wire via the prybar..otherwise the plates will bend in the vise and make a mess of removing wire..
Philip Davies (Oct 31, 2021)
